I am having trouble with connecting atmel ice. FYI im a newbie with the ice.
For this I am using atting4313-pu.
Problem 1)
I am 100% sure I am wiring it correctly from the header plug to the micro but I do not get a green light indicating a good power supply to target. Also under target voltage I will get a negative voltage.
However when I connect VCC to GND rail and GND to VCC rail I get a green light. Im certain this can not be correct as I have used this power supply multiple times before and it has worked correctly.
Problem 2)
I get this pop up when I try run:
and then get this one:
I have no idea what is wrong here, so any help with be helpful.
Problem 1)
Problem 2)
