Atari 800 repair / RF video out issues
spinnaker
Joined Oct 29, 2009
7,830
If you have a non-inductive resistor(s) at 50Ω, and a couple of BNC connectors (male and female), you can make one.
Keep it as short as possible, the resistance goes across the center and shield.
A carbon film resistor would work?
Just measure across the resistor?
spinnaker
Joined Oct 29, 2009
7,830
Mentioned above but just as a reminder. My 5V is a bit low. 4.89V. Is that common on the 7805? If not. what would cause the low voltage?
spinnaker
Joined Oct 29, 2009
7,830
So what was I doing wrong when trying to measure RF? I had 2 100 ohms in parallel and measured across the resistor. I solder them to an audio / video jack , so I know I had a good connection.
Ya’akov
Joined Jan 27, 2019
10,370
I don't know. It sounds like it should have been correct.
Was the terminator right next to the scope?
spinnaker
Joined Oct 29, 2009
7,830
Terminator qas at the end of the RF cable. Not sure what you mean by "next to the scope". Did it need to go between the scope and test lead?
Ya’akov
Joined Jan 27, 2019
10,370
Yes, the purpose is to make the scope appear to be a 50Ω load. Some scopes allow setting the impedance of the input but the Siglent is fixed, that's the reason for the terminator.
