AT89S52 recceive code but does not working
pa1
Joined Feb 9, 2017
The AT89S52 receive hex code but does not working , what should I do now & where is my problem?
LesJones
Joined Jan 8, 2017
4,543
We need some information to work with. Post a FULL schematic and a FULL listing of the code. Also is the HEX code entering via a parallel port or via the UART ?
Les.
DickCappels
Joined Aug 21, 2008
10,661
Along with LesJones's questions, what indication do you have that the hex file was programmed into the chip and that it is correct?
LesJones
Joined Jan 8, 2017
4,543
Hi Dick,
Reading your post made me realise that I was not clear enough. I was interpreting the question as that the micro did not respond to a hex code sent to it while the program was running. I now realise that the OP could mean that he is not able to load the .HEX program file into the chip.
