Are these two Varistors are same?
Mussawar
Joined Oct 17, 2011
158
I found a burned varister in an industrial card. Marking says S14-K510. I was able to find a piece in local market which is marked as 14D-511K. Just want to conform if they are the same thing or not? I know the voltage of both are 510V. Does "S14" and "14D" make any critical difference?
[Edit]: Apparently, both varistors are almost same color, shape and size.
Regards.
liaifat85
Joined Sep 12, 2023
200
If you don't have access to datasheets, and the new varistor physically fits and has a similar voltage rating (510V), it should work as a replacement.
