Are these power supplys interchangeable??
bodydub
Joined Oct 17, 2018
I purchased a power supply online for a led light. But before I go plugging it into a LED light I just want to be sure it will work. It will be plugged into two led strips for a total of 8 watts.
Old one
New one
dl324
Joined Mar 30, 2015
18,453
Welcome to AAC!
At first glance, the substitution seems okay.
To know for certain, you need to measure the output of both to see if they're actually 12V. If they aren't, you need to find out if your light would be sensitive to the difference.
bodydub
Joined Oct 17, 2018
So "yes" according to the specs in the pics? And to testing the output. Wouldn't that be going above and beyond by measuring it?
Thank you for your responses.
dl324
Joined Mar 30, 2015
18,453
Not if you don't want to risk the light. All power adapters aren't alike. Some give a higher voltage at lower currents, some don't. Some are regulated, and some aren't.
It's cheap insurance to measure to be certain.
FriendlyGuru
Joined Oct 17, 2018
7
And i bet the current is
Especially cheap chinese ones with fake amp (current)
28,129
Most of the linear non-regulated DC wall warts have a higher terminal voltage at a lighter load current. So exactly like has been said already, you need to measure the voltage provided by the device you want to use. OR, you can add a variable high power resistor in series with the LED light, and adjust the resistance value until the voltage at the light is correct.
