arduino_color sensor 34725
Dabu WhiteHacker
Joined Sep 5, 2017
68
i was using color sensor 34725 with arduino to detect colors
but it seems it is working a bit strange
i have uploaded the picture of the data i gather from my experiment
here are the confusing things
1.why green value is also high when i place sensor on blue paper?
2.why green and red color are significantly more in yellow as compared when they are place on their own color.
and so on, i mean the color sensor does not seem to work properly
Raymond Genovese
Joined Mar 5, 2016
1,653
You have to remember how that sensor is working. You are basically using ADC values from different red, green, blue, and clear light photo-diode sensors. I haven't looked real carefully, but what it looks like you are getting is not unusual at all.
One way of using the information to identify colors is to use the values to calculate x and y chromaticity coordinates. I took a stab at doing this with the TCS34725 and I was actually pretty amazed at the results that I got - see here if you think it might help.
I would add that if I were going to do it again, to build a color sorter for example, I would choose a more advanced chip that actually gives you the x,y,z coordinates - something like this one or this one.
Alec_t
Joined Sep 17, 2013
15,119
If you are using the sensor to check the colour of a printed item, a lot will depend on the reflectance of the inks used and also on the illuminating light source. It is doubtful that a supposedly red printed item would reflect pure red, for example.
