Arduino - Type error, help please
djsfantasi
Joined Apr 11, 2010
9,237
I just noticed the "goto" statement in yout if statement. We need to find a way to code that logic, so the "goto" is not needed. I'm of the camp that says goto is rarely, if not ever, needed. If it is used to pass control out of a code block with locally defined variables, yu are going to get memory corruption. I'd much rather use break to exit while and for loops and if I have to, define a boolean to indicate the break occurred and then goto the desired location... IF THATS THE ONLY WAY TO GET THE FLOW NEEDED. In your case, a band-aid approach would be to create another loop and when you execute the break command, execution would fall to the outer (new) loop end and it would repeat.
Oh, and I also just noticed your use of label: and its associated goto's. You are re-defining a string over and over, each time you goto label:. This is bound to cause memory problems. I'd move the definition of test_str to the beginning of the function, where it will only be executed once.
You may find this (click here->) library useful when debugging. You can keep track of free memory with debug statements (Serial.println)
flat5
Joined Nov 13, 2008
403
Edit: (May 15!)
"Oh, and I also just noticed your use of label: and its associated goto's. You are re-defining a string over and over, each time you goto label:. This is bound to cause memory problems."
User input defines a string. I should sketch a goto loop that just defines a string and prints it. See if it crashes.
A while loop will not work. I have to break the function into a few functions and see how that goes.
Edit: This is the key. Clean up the prog and remove redundancies.
Organize stuff into procedures.
flat5
Joined Nov 13, 2008
403
Well, testing do - while anyway.
If legitimate characters are input after the prompt, sometimes the first one is ignored. Error traps are inconsistant.
May a do loop have more than one while?
Code:
void subset_test()   // Select characters for study
  unsigned int randNumber; String send_char; String answers;
  byte chk;
  String test_str;
  do // <--------------------------- area of interest. sometimes reports the correct error. sometimes hangs on the second pass
    chk = true;
    test_str = "";
    Serial.flush();
    Serial.println(F("Input characters. Then press Enter to continue")); // must be a better way to say this
    Serial.setTimeout(10000);
    test_str.concat(Serial.readStringUntil('\r')); // 10 seconds or 'Enter' key
    Serial.setTimeout(1000); // reset key timeout to a more reasonable length
    test_str.toLowerCase();
    if (test_str.length() > 43)
      Serial.println(F("Max:44 characters"));
      chk = false;
      while (chk == false); // hopefully jumps back to 'do'
    for (unsigned int t = 0; t < test_str.length(); t++) // test to see if the string has duplicates
      char h; // overcoming the string vs char compile error by CASTING
      h = char(test_str.charAt(t));
      if (h == char(test_str.charAt(t + 1))) //-------------------------
        Serial.println(F("Repeated character!")); // "Repeated character not allowed."
        chk = false;
  } while (chk == false); <--------------------- working on this right now ---------------------------------------
  char* send_codes[test_str.length()];
  for (unsigned int t = 0; t < test_str.length(); t++) // build string to be sent
    randNumber = random(test_str.length() + 1);
    if (answers.indexOf(test_str[randNumber]) != -1) t = t - 1; // character already in array. try again
    else
      answers.concat(test_str[randNumber]); answers.concat(" "); // add a space after each character for readability
      for (unsigned int i = 0; i < 44; i++)
        if (test_str.substring(randNumber, randNumber + 1) == code_char[i]) // to index the correct code string
          send_codes[t] = codes[i];
        //   else { // Serial.print(test_str.substring(randNumber)); Serial.println(" is not a character in the Morse array.");
        //}          // Still working on this error trap
  for (unsigned int t = 0; t < test_str.length(); t++) // send the code
    send_char = send_codes[t]; // send the code of a character
    send_code(send_char);       // function call
  Serial.println(answers);
flat5
Joined Nov 13, 2008
403
updated code. full program.
t option still troublesome. Sometimes the first character entered by user is not in the string.
Edit: randNumber = random(test_str.length()); <---I caught a bug! Was (test_str.length() + 1)
t is better now :)
Code:
// Morse Receive Practice v1.1
// by flat5 May-13-2015
// choice of tone/notone or external oscillator.
// Plug speaker to Analog pin8 and gnd. Use a resistor or pot in series if you want to. I used 220 ohm.
#include <Arduino.h>
unsigned int pitch = 0;          // *** I'm using an oscillator. You might want to use 600, for example. ***
unsigned long int baud = 115200; // *** 115200 57600 9600 make sure the term prog matches!               ***
byte term = true; //false        // *** If you are not using a good terminal program and the screen has weird
//                               // characters at the beginning of some lines change this from true to false
byte signalPin = 13; // will control oscillator speaker
unsigned int wpm = 15;           // Change this to any default value
unsigned int elementWait = 1200 / wpm;
unsigned int row = 43;           // do not make this number larger than 43!
unsigned int space = 2; // time between characters. It is good to send the chacters faster than the space between them for practice.
char* codes[] =
  "-.", "---", ".--.", "--.-", ".-.", "...", "-", "..-", "...-", ".--", "-..-", "-.--", "--..", // 26 letters
  "-----", ".----", "..---", "...--", "....-", ".....", "-....", "--...", "---..", "----.",     // 10 numbers
  "--..--", ".-.-.-", "..--..", "..--.", "---...", ".-..-.", ".----.", "-...-"                  //  8 punctuation
char* code_char[] =
{ "a", "b", "c", "d", "e", "f", "g", "h", "i", "j", "k", "l", "m",
  "n", "o", "p", "q", "r", "s", "t", "u", "v", "w", "x", "y", "z", // 26 letters
  "0", "1", "2", "3", "4", "5", "6", "7", "8", "9",                // 10 numbers
  ",", ".", "?", "!", ":", "\"", "'", "="                          // 8 punctuation, so far - 44 characters
void setup() {
  pinMode(signalPin, OUTPUT);
  noTone(8);
  Serial.begin(baud); //115200 - 9600
  randomSeed(analogRead(0));
  code_chart();
  menu();
void loop()
  parser();
void menu() {
  Serial.println(F("Send a random group of characters for Morse practice"));
  Serial.println(F("Press Spacebar to start"));
  Serial.println(F("'s'(value) to adjust letter space (1-255)"));
  Serial.println(F("'w'(value) to adjust wpm (Example: w20)"));
  Serial.println(F("'p'(value) to set tone pitch <p31-24000 or 'p' for off"));
  Serial.println(F("'r'(value) to set number of characters to send (1-88)"));
  Serial.println(F("'t'(characters) to input characters to send (44 max)"));
  Serial.println(F("'u' to send the punctuation characters"));
  Serial.println(F("'m' to display this menu"));
  Serial.println(F("'c' to clear screen on real terminals"));
  Serial.println(F("'d' to show Morse code chart"));
  Serial.print("Currently: s:"); Serial.print(space); Serial.print(" w:"); Serial.print(wpm);
  Serial.print(" r:"); Serial.print(row); Serial.print(" P:"); Serial.println(pitch);
  //Serial.println("Currently: s:"+space+" w:"+wpm+" r:"+row+" P:"+pitch+"\n"); // boo hoo. wish this worked
  Serial.println();
void parser()
  Serial.print("<"); // It gives some indication that the prog has not crashed and is awaiting instructions
  unsigned int digits;
  unsigned int value = 0;
  do
    digits = Serial.available();
  while (digits < 1);
  char keypress = Serial.read();
  do
  while (digits < 0);
  value = Serial.parseInt();
  Serial.flush();
  if (term == true) Serial.write(8);
  switch (keypress)
    case 'm': case 'M': case 'h': case 'H': case '?': // display menu
        menu();
        break;
    case ' ': // Spacebar. generate code
        random_code();
        break;
    case 't': case 'T': // send a selected group of characters
        subset_test();
        break;
    case 'u': case 'U': // send the punctuation characters
        send_punc();
        break;
    case 's': case 'S': // letter space time length (1 is same time as a dit)
        if (value != 0) space = value; // value 0 not allowed. just report setting
        Serial.print("Letter space time: "); Serial.println(space);
        break;
    case 'w': case 'W': // wpm
        if (value != 0) wpm = value; // value 0 not allowed. just report setting
        elementWait = 1200 / wpm; // dit = 1200 / wpm
        Serial.print("wpm: "); Serial.println(wpm);
        break;
    case 'r': case 'R': // how many to send (a row)
        if (value != 0 && value < 89)
          row = value;
          Serial.print(row); Serial.println(F(" characters will be sent"));
          break;
        else
        { Serial.print(F("value (1-88), presently ")); Serial.println(row);
          break;
    case 'c': case 'C':
        refresh_Screen(); // a real terminal is required for this to work
        break;
    case 'p': case 'P':
        pitch = value;
        if (pitch == 0)
          pitch = 0;
          noTone(8);
          Serial.println(F("Tone off.")); // stare at the led or use an external oscillator triggered by pin D13
          break;
        if (pitch < 31 || pitch > 24000)
          Serial.println(F("Pitch range: 31-24000"));
          break;
        Serial.print(F("Tone pitch in Hz: ")); Serial.println(pitch, DEC);
        tone(8, pitch, 400); // give a sample
        break;
    case 'd': case 'D':
        refresh_Screen();
        code_chart();
        break;
void refresh_Screen() // not compatable with all terminal programs
  if (term == true)
    Serial.write(27); // ESC
    Serial.write("[2J"); // clear screen
    Serial.write("[H"); // cursor to home
void dit_dah(String x)
  digitalWrite(signalPin, HIGH);
  if (pitch != 0) tone(8, pitch);
  if (x == ".") delay(elementWait); // milliseconds - one dit
  else if (x == "-") delay(elementWait * 3);
  digitalWrite(signalPin, LOW);
  noTone(8);
  delay(elementWait);
void letter_space() {
  delay(elementWait * space);
void random_code() // send a random character's Morse equivlent
  String send_char; String answers; String answers2;
  char* send_codes[row]; //array starts at 0. User inputs how many characters in a run (row on screen)
  for (unsigned int t = 0; t < row; t++) // each run will be 'row' characters (+ 'row' spaces) but the last check needs a kludge
    unsigned int randNumber = random(44); // 0 - 43, all characters.
    // see if the randNumber character is in string 'answers' or 'answers2' already.
    if (t < 44)
      if (answers.indexOf(code_char[randNumber]) != -1) t = t - 1; // character already in array. try again
      else
        answers.concat(code_char[randNumber]); answers.concat(" "); // add a space after each character for readability
        send_codes[t] = (codes[randNumber]); // build array of code character strings to be sent
    if (t > 43 )
      if (answers2.indexOf(code_char[randNumber]) != -1) t = t - 1;
      else
        answers2.concat(code_char[randNumber]); answers2.concat(" ");
  for (unsigned int t = 0; t < row ; t++)
  Serial.print(answers); Serial.println(answers2 + "\n"); //Serial.println(); // show test answers & answers2, if any
void subset_test()   // Select characters for study -------still working on this one
  unsigned int randNumber; String send_char; String answers; String test_str;
  Serial.flush();
  //if (term == true) Serial.write(8);
    Serial.println(F("Max:44 characters - quiting routine"));
    return; // quit the routine
      Serial.println(F("Repeated character! - quiting routine")); // "Repeated character not allowed."
  delay(2000); // pick up a pencil time
    randNumber = random(test_str.length()); // (test_str.length() + 1) was a bug that caused a missing character in output
    else
        //else { // Serial.print(test_str.substring(randNumber)); Serial.println(" is not a character in the Morse array.");
        //} // Still working on this error trap. Not really needed. A wrong character is not processed (ignored).
  Serial.println(answers + "\n");
void send_punc() // send just punctuation characters
  String punc = (",.?!:\"'="); String answers; unsigned int randNumber; String send_char; unsigned int rand_order[8];
  for (unsigned int t = 0; t < 8; t++)
    randNumber = random(8);
    if (answers.indexOf(punc[randNumber]) != -1) t = t - 1; // character already in array. try again
    else
      answers.concat(punc[randNumber]); // build answers string
      rand_order[t] = randNumber;
    send_char = codes[rand_order[t] + 36]; // get code string for character in answers[index]
void send_code(String send_char)
  for (unsigned int i = 0; i < send_char.length(); i++) // break it down to it's elements and send
    String x;
    x = send_char.substring(i, i + 1);
    dit_dah(x); // determine dit or dah and send
  letter_space();
void code_chart()
  unsigned int i;
  Serial.println(F("letters:")); // I wish I had more control over auto format. Like an IDE comment instruction to leave it alone.
  for (i = 0; i < 13; i++) {
    print_line(i);
  } Serial.println(); Serial.println();
  for (i = 13; i < 26; i++) {
    print_line(i);
  Serial.println(F("numbers:"));
  for (i = 26; i < 36; i++) {
    print_line(i);
  Serial.println(F("punctuation:"));
  for (i = 36; i < 44; i++) {
    print_line(i);
void print_line(unsigned int i)
  Serial.print("(");
  Serial.print(code_char[i]);
  Serial.print(")");
  Serial.print(codes[i]);
  Serial.print(" ");
flat5
Joined Nov 13, 2008
403
Cleaned up the code. Restructured the flow and cut some redundancies. Everything works but I'm sure the code could be more Elle Gante.
Code:
// Morse Receive Practice v2.2
// by flat5 May-15-2015
const unsigned long int baud = 115200; // *** 115200 57600 9600 300 2 make sure the term prog matches!   ***
//                               // *** characters at the beginning of some lines change this from true to false
byte Get_ready = 2000;           // *** pause before test characters are sent. You might want to change this ***
const byte signalPin = 13; // will control oscillator speaker
unsigned int wpm = 20;           // Change this to any default value
unsigned int space = 3; // Default time between characters. It's good to send characters faster than the space between them for practice.
String testStr; unsigned int randNumber; String send_char; String answers; unsigned int error = 0;
char* codes[] =
char* code_char[] =
void setup() {
  noTone(8);
  Serial.begin(baud); //115200 - 9600 - 300 - 1
  code_chart();
  menu();
void loop()
  parser();
void menu() {
  Serial.println(F("'t'to select characters to send (44 max) or just Enter to clear them"));
  Serial.print(F("Currently: s:")); Serial.print(space); Serial.print(F(" w:")); Serial.print(wpm);
  Serial.print(F(" r:")); Serial.print(row); Serial.print(F(" P:")); Serial.print(pitch);
  Serial.print(F(" TestString:")); Serial.println(testStr);
  Serial.println();
void parser()
  Serial.print(F("<")); // It gives some indication that the prog has not crashed and is awaiting instructions
  do
  while (digits < 1);
  do
  while (digits < 0);
  Serial.flush();
  switch (keypress)
    case 'm': case 'M': case 'h': case 'H': case '?': case 'i': case 'I': // display menu
        if (keypress == 'i' || keypress == 'I')
          refresh_Screen();
          Serial.println(F("Morse Receive Practice v2.2 developed by Barry Block\n"));
        menu();
        break;
        random_code();
        break;
        build_testStr();
        break;
        testStr = ",.?!:\"'=";
        Serial.println(F("TestStr set to puncuation characters: ,.?!:\"'="));
        break;
        Serial.print(F("Letter space time: ")); Serial.println(space);
        break;
        Serial.print(F("wpm: ")); Serial.println(wpm);
        break;
          row = value;
          break;
        else
          break;
    case 'c': case 'C':
        break;
    case 'p': case 'P':
        pitch = value;
        if (pitch == 0)
          pitch = 0;
          noTone(8);
          break;
          break;
        break;
    case 'd': case 'D':
        refresh_Screen();
        code_chart();
        break;
  if (term == true)
  noTone(8);
  delay(elementWait);
  if (testStr != "") // characters have been selected so just send them. Idea is to always use the Spacebar to send a test run
    send_select();
    return;
  String answers2;
    if (t < 44)
      else
        send_codes[t] = (codes[randNumber]); // build string array of code characters to be sent, in Morse form
    if (t > 43 )
      else
  Serial.println(answers); if (row > 43) Serial.println(answers2 + '\n'); // show test answers & answers2, if any
  answers = "";
void send_select() // called when testStr has proved legal
  char* send_codes[testStr.length()];
  for (unsigned int t = 0; t < testStr.length(); t++) // random up the string to be sent
    randNumber = random(testStr.length());
    if (answers.indexOf(testStr[randNumber]) != -1) t = t - 1; // character already in array. try again
    else
      answers.concat(testStr[randNumber]); answers.concat(" "); // add a space after each character for readability
        if (testStr.substring(randNumber, randNumber + 1) == code_char[i]) // to index the correct code string
  for (unsigned int t = 0; t < testStr.length(); t++) // send the code
  Serial.println(answers + "\n"); answers = ""; // display test answers and clear the string for the next run
void build_testStr()   // Select characters for study (option t)
  inString_build(); // collect chars and put in testStr if they are legal
  if (error == 1)
    error = 0;
    return;
  Serial.print(F("TestString: ")); Serial.println(testStr);
void inString_build() // get chars from user and check them. if ok add them to testStr
  Serial.flush();
  Serial.println(F("Input characters & Enter to save a TestString or just Enter to clear the string.\n"));
  testStr = collect_chars(testStr); //build testString
  // now test the string for problems
  if (testStr.length() > 43)       // is the string too long? larger than the array of Morse characters
    Serial.println(F("Max:44 characters - TestString nulled"));
    error = 1;
    testStr = "";
    return;
  for (unsigned int t = 0; t < testStr.length(); t++) // check for duplicates
    h = char(testStr.charAt(t));
    if (h == char(testStr.charAt(t + 1))) // position t+1 to the end of string
      Serial.println(F("Repeated character! - TestString nulled"));
      error = 1;
      testStr = "";
      return;
  for (unsigned int s = 0; s < testStr.length(); s++) // for each char of testStr...
    error = 1; // setting a flag
    for (unsigned int i = 0; i < 44; i++) // check to see that the character is a known Morse char.
      if (testStr.substring(s, s + 1) == code_char[i]) // if a match is found for this char set a flag. don't check further
        error = 0;
        break;
    if (error == 1) // illegal character. kill testStr and return. don't check rest of testStr.
      Serial.print(testStr.substring(s, s + 1));
      Serial.println(F(" is not a character in the Morse array. TestSring nulled"));
      testStr = "";
      error = 1;
      return;
String collect_chars(String testStr) // user input to build testStr
  testStr = "";
  char inChar;
  while (Serial.read() == '\r');
  Serial.flush();
  delay(10); // seems to have removed the odd glitch
  while (Serial.available() < 1)
    inChar = Serial.read();
    if (inChar > 31 && inChar < 127) testStr = testStr + inChar; // screen gets filled with garbage without this check
    else if (inChar == '\r')
      testStr.toLowerCase();
      return testStr;
void send_code(String send_char) // send the dits & dahs
  for (unsigned int i = 0; i < send_char.length(); i++) // break the Morse char string down to it's elements and send
    String x;
  letter_space();
void code_chart()
  unsigned int i;
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
  Serial.print("("); Serial.print(code_char[i]); Serial.print(")"); Serial.print(codes[i]); Serial.print(" ");
flat5
Joined Nov 13, 2008
403
I think the program is quite useful at this point. I'd like to know of a beginner's ham site to consider uploading it. First have to see what else is offered there.
Edit: added 8 more punctuation characters. Added a feature or two. Caught a few bugs.
Code:
// Morse Receive Practice v2.4
// by flat5 May-31-2015
// Plug speaker to Analog pin8 and gnd. Use a resistor or pot in series if you want to. I used 220 ohms.
// A few more punctuation characters added. Added a feature or two. Caught a few unwanted features.
unsigned int pitch = 830; //0    // *** I'm using an oscillator, not tone(). You might want to use 600Hz, for example.
unsigned int key_wait = 0000;    // *** pause to give you time to enter data, in milliseconds. for slow typers Ex. 0,1,2,3 (in menu)
unsigned int space = 3;          // *** Default time between characters.
//                               //     It's good to send characters faster than the space between them for practice.
const byte signalPin = 13;       // *** will control oscillator speaker
unsigned int wpm = 20;           // *** Change this to any default value
unsigned int row = 52;           // *** do NOT make this number larger than the array - 52!
unsigned int testStrRow;
char* codes[] =
  "..-.--", "-.--.", "-.--.-", "..--", ".-...", "-.-.-.", ".-.-."                               // 16 punctuation
char* code_char[] =
  ",", ".", "?", "!", ":", "\"", "'", "=", "@", "_", "(", ")", "^", "&", ";", "+"               // 16 punctuation - 52 characters (0-51)
void setup() {
  noTone(8);
  Serial.println(F("Morse Receive Practice v2.4 developed by Barry Block\n"));
  menu();
  code_chart();
void loop()
  parser();
void menu() {
  Serial.println(F("Press Spacebar to start test\n"));
  Serial.println(F("s(value) adjust letter spacetime (1-255)"));
  Serial.println(F("k(value) adjust keypress timeout in seconds(0-10)"));
  Serial.println(F("w(value) adjust wpm (Example: w20)"));
  Serial.println(F("p(value) adjust tone pitch <p31-24000 or 'p' for off"));
  Serial.println(F("r(value) adjust number of characters to send (row length: 1-104)"));
  Serial.println(F("t select characters to send (52 max) or just Enter to clear 'TestString'"));
  Serial.println(F("n send numbers"));
  Serial.println(F("l send letters"));
  Serial.println(F("u send punctuation characters"));
  Serial.println(F("c clear screen on real terminals"));
  Serial.println(F("d show Morse code chart"));
  Serial.println(F("m display this menu"));
  Serial.print(F("Currently: s:")); Serial.print(space); Serial.print(F(" k:")); Serial.print(key_wait / 1000);
  Serial.print(F(" w:")); Serial.print(wpm); Serial.print(F(" P:")); Serial.print(pitch); Serial.print(F(" r:"));Serial.print(row);
  if (testStr != "")
    Serial.print(F(" TestString row:")); Serial.print(testStrRow); Serial.print(F(" TestString: ")); Serial.print(testStr);
  Serial.println();
void parser()
  do
  while (digits < 1);
  delay(key_wait);
  do
  while (digits < 0); // I do not understand this
  Serial.flush();
  if (term == true) Serial.write(8); // backspace
  switch (keypress)
    case ' ': // Spacebar. generate & send code
        random_code();
        break;
    case 'c': case 'C':
        break;
    case 'd': case 'D':
        refresh_Screen();
        code_chart();
        break;
    case 'k': case 'K': // keypress timeout
        if (value < 11)
          key_wait = value * 1000;
        Serial.print(F("KeyWait: ")); Serial.println(key_wait / 1000);
        break;
    case 'l': case 'L': // send the punctuation characters
        testStr = "abcdefghijklmnopqrstuvwxyz";
        Serial.println(F("TestString set to letters"));
        shortRow();
        if (testStrRow > 26)
          Serial.println(F("1-26 characters!"));
          testStrRow = 26;
        break;
        if (keypress == 'i' || keypress == 'I' || keypress == '?')
          refresh_Screen();
        menu();
        break;
    case 'n': case 'N': // send the punctuation characters
        testStr = "1234567890";
        Serial.println(F("TestString set to numbers"));
        shortRow();
        if (testStrRow > 10)
          Serial.println(F("1-10 characters!"));
          testStrRow = 10;
        break;
    case 'p': case 'P':
        pitch = value;
        if (pitch == 0)
          pitch = 0;
          noTone(8);
          break;
          break;
        break;
        if (value == 0)
          Serial.print(F("row length (1-104), presently ")); Serial.println(row);
          if (testStr != "")
            Serial.print(F("TestString row length: ")); Serial.println(testStrRow);
          break;
        if (testStr != "")
          if (value <= testStr.length())
            testStrRow = value;
            Serial.print(testStrRow); Serial.println(F(" characters will be sent while using current TestString"));
            break;
          else
            Serial.print(F("Too high a number! TestString is only ")); Serial.print(testStr.length()); Serial.println(F(" characters."));
            break;
        else if (value < 105)
          row = value;
          break;
        else
          Serial.println(F("Too high a number!(1-104)"));
          break;
        break;
        testStrRow = 0;
        build_testStr();
        break;
        testStr = ",.?!:\"'=@_()^&;+";
        Serial.print(F("TestString set to puncuation characters: ")); Serial.println(testStr);
        shortRow();
        if (testStrRow > 16)
          Serial.println(F("1-16 characters!"));
          testStrRow = 16;
        break;
        break;
void refresh_Screen() // not compatible with all terminal programs
  if (term == true)
  noTone(8);
  delay(elementWait);
void random_code() // send a random character's Morse equivalent
    send_select();
    return;
  String answers2;
    randNumber = random(52); // 0 - 51, all characters.
    if (t < 52)
      else
    if (t > 51 )
      else
  Serial.println(answers); if (row > 52) Serial.println(answers2 + '\n'); // show test answers & answers2, if any
  answers = "";
  if (testStrRow == 0) testStrRow = testStr.length();
  char* send_codes[testStrRow];
  for (unsigned int t = 0; t < testStrRow; t++) // random up the string to be sent
    else
      for (unsigned int i = 0; i < 52; i++)
  for (unsigned int t = 0; t < testStrRow; t++) // send the code
  Serial.println(answers); answers = ""; // display test answers and clear the string for the next run
  inString_build(); // collect chars and put in testStr if they are legal. if not, return error 1
  if (error == 1)
    error = 0;
    return;
  if (testStr != "") // testStr is legal
  Serial.flush();
  testStr = collect_chars(testStr); //get user input
  if (testStr == "")
    Serial.println(F("TestString cleared"));
    return;
  if (testStr.length() > 52)       // is the string too long? larger than the array of Morse characters
    Serial.println(F("Max:52 characters - TestString cleared"));
    error = 1;
    testStr = "";
    return;
      Serial.println(F("Repeated character! - TestString cleared"));
      error = 1;
      testStr = "";
      return;
    for (unsigned int i = 0; i < 52; i++) // check to see that the character is a known Morse char.
        error = 0;
        break;
      Serial.println(F(" is not a character in the Morse array. TestSring cleared"));
      testStr = "";
      error = 1;
      return;
  testStr = "";
  char inChar;
  Serial.flush();
      return testStr;
    String x;
  letter_space();
void shortRow() // row length for the users input test string
  char inChar;
  String inString;
  testStrRow = 0;
  Serial.println(F("Input how many characters to send or just Enter to send all"));
  Serial.flush();
    delay(10);
    if (inChar > 47 && inChar < 58) inString = inString + inChar; // if a number add to string
      testStrRow = inString.toInt();
      return;
void code_chart()
  unsigned int i;
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
  for (i = 44; i < 52; i++) {
    print_line(i);
  Serial.print("["); Serial.print(code_char[i]); Serial.print("]"); Serial.print(codes[i]); Serial.print(" ");
Screen shot
flat5
Joined Nov 13, 2008
403
Latest version 2.5. Added SDcard to store/send a random textfile.
This is pushing the memory to the limit so could use help optimising the code where possible.
Specific suggestions welcome as my coding skills are VERY basic. I'd like to think I've improved them by working on this project.
I will update the code and place it here rather than a new post.
Code:
// Morse Receive Practice v2.5
// by flat5 June-4-2015
// UK/US characters only
// choice of tone/notone or external oscillator circuit triggered by pin13.
// Plug speaker to Digital pin8 and gnd. Use a resistor or pot in series if you want to. I used 220 ohms.
// v2.5 added SD card. randomly chooses textfile to send as Morse
// This has pushed the memory to the limit. Had to remove a few things. Could use some help to to improve this situation!
#include <SPI.h>
#include <SD.h>
const int chipSelect = 4; // SD card select
byte SDready; // SD card installed, true or false
byte echo;
unsigned int fileCount = 10;     // *** number of textfiles in SD root folder. They must be named 0 1 2...9 no more!
//                               //     with no extension. They will be picked randomly. Had to save memory here.
const byte signalPin = 13;       // *** will control oscillator speaker, if using my circuit. else connect sounder to D8
String testStr; unsigned int testStrRow; unsigned int randNumber; String send_char; String answers; unsigned int error = 0;
char* codes[] =
char* code_char[] =
void setup() {
  noTone(8);
  Serial.print(F("Initializing SD card...")); // see if the SD card is present and can be initialized:
  if (!SD.begin(chipSelect))
    SDready = false;
    Serial.println(F("SD card failed, or not present"));
    delay(3000);
  else
    Serial.println(F("SD card initialized."));
    SDready = true;
    //countRootFiles();
  refresh_Screen();
  Serial.println(F("Morse Receive Practice v2.5 developed by Barry Block\n"));
  menu();
  // code_chart();
void loop()
  parser();
void menu() {
  Serial.println(F("r(value) adjust number of characters to send (row length: 1-52)"));
  if (SDready) Serial.println(F("f send a textfile from SD card. add a number for text echo (f4)"));
  if (term) Serial.println(F("c clear screen on real terminals"));
  Serial.print(F(" w:")); Serial.print(wpm); Serial.print(F(" P:")); Serial.print(pitch); Serial.print(F(" r:")); Serial.print(row);
  if (testStr != "")
  Serial.println();
void parser()
  do
  while (digits < 1);
  delay(key_wait);
  do
  Serial.flush();
  switch (keypress)
        random_code();
        break;
    case 'c': case 'C':
        break;
    case 'd': case 'D':
        refresh_Screen();
        code_chart();
        break;
    case 'f': case 'F':
        if (SDready == false)
          Serial.println(F("no SD card found"));
          break;
        if (value > 0) {
          echo = true;
        else {
          echo = false;
        refresh_Screen();
        send_SDtext();
        break;
        if (value < 11)
        break;
        shortRow();
          testStrRow = 26;
        break;
          refresh_Screen();
        menu();
        break;
        shortRow();
          testStrRow = 10;
        break;
    case 'p': case 'P':
        pitch = value;
        if (pitch == 0)
          pitch = 0;
          noTone(8);
          break;
          break;
        break;
        if (value == 0)
          Serial.print(F("row length (1-52), presently ")); Serial.println(row);
          if (testStr != "")
          break;
        if (testStr != "")
            testStrRow = value;
            break;
          else
            break;
        else if (value < 53)
          row = value;
          break;
        else
          Serial.println(F("Too high a number!(1-52)"));
          break;
        break;
        testStrRow = 0;
        build_testStr();
        break;
        shortRow();
          testStrRow = 16;
        break;
        break;
  if (term == true)
  noTone(8);
  delay(elementWait);
void word_space() {
  delay(elementWait * space * 2); // close enough
    send_select();
    return;
    else
  Serial.println(answers); answers = ""; // show test answers and clear string
    if (answers.indexOf(testStr[randNumber]) != -1) t--; // character already in array. try again
    else
  if (error == 1)
    error = 0;
    return;
  Serial.flush();
  if (testStr == "")
    return;
    error = 1;
    testStr = "";
    return;
      error = 1;
      testStr = "";
      return;
    error = 1; // set a flag
        error = 0;
        break;
      testStr = "";
      error = 1;
      return;
  testStr = ""; char inChar;
  Serial.flush();
      return testStr;
void send_code(String send_char) // send the dits & dahs of the Morse string - codes[](Ex. .-..)
    String x;
  letter_space();
  char inChar; String inString;
  testStrRow = 0;
  Serial.flush();
    delay(10);
      return;
void code_chart()
  unsigned int i;
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
void send_SDtext()
  String str; char fname[2]; // fails if > 3 !
  unsigned int rand = random(fileCount);
  str = String(rand);        // convert int to string
  str.toCharArray(fname, 2); // convert string to char array
  Serial.print(F("textfile: ")); Serial.println(fname); Serial.println();
  File dataFile = SD.open(fname, FILE_READ);
  // if the file is available, READ from it.
  // This routine is fast enough that >3000 wpm seems to be sent with no jerkyness.
  if (dataFile)
    String send_char; int SDint; String printChar;
    while (dataFile.available())
      SDint = dataFile.read();
      char c = char(SDint);   // int to char
      send_char = String(c);  // char to string
      printChar = send_char;
      send_char.toLowerCase();
      for (unsigned int i = 0; i < 52; i++) // check to see that the character is a known Morse char or space
        if (send_char < " " || send_char > "z")
          break;
        if (send_char == " ")
          word_space();
          break;
        if (send_char == code_char[i]) // if a match is found for this char, send it
          send_char = codes[i];
          break;
      if (echo == true) Serial.print(printChar); // It's fun to see the text as the code is being sent.
    dataFile.close();
    Serial.println();
    if (echo == false)
        Serial.write(dataFile.read());
      dataFile.close();
    Serial.println();
  else // if the file isn't open, pop up an error:
    Serial.print(F("error opening ")); Serial.println(fname);
// "That's all, Folks"
flat5
Joined Nov 13, 2008
403
OK, I lied. This is a memory re-write and some cleanup. Gave me some room to add a feature. SD fileCount.
Dynamic memory used is only 51% now! I think moving the two big(ish) arrays to flash memory has improved the speed of the prog so I re-wrote and simplified things in a few places. Worth the effort. I'm learning! (maybe)
Next is to add saving and deleting a file on the SD card.
version 2.6
Code:
// Morse Receive Practice v2.6
// by flat5 June 6, 2015
// This had pushed the memory to the limit.
// This version is a rewrite of how static strings are stored. Only 51% of dynamic memory is used!
// NOTE - number of textfiles in SD root folder must be named 0 1 2...98...127...999
// Not tested beyond 61 yet! format to Fat32 & avoid 'too many files' error. array will not work with 4 digit numbers unless YOU change it
// I may implement a few things I did not have the memory for.
#include <avr/pgmspace.h>
#include <SPI.h>
#include <SD.h>
String Brag = "Morse Receive Practice v2.6 developed by Barry Block\n";
byte echo;
byte SDready = true;             // *** SD card installed, true or false. set to false if no SD card to avoid error message
unsigned int space = 3;          // *** Default time between Morse characters.
String testStr; unsigned int testStrRow; String send_char; String answers; unsigned int error; File root; unsigned int fileCount = 0;
const char str0[] PROGMEM = "a";  const char str1[] PROGMEM = "b";  const char str2[] PROGMEM = "c";  const char str3[] PROGMEM = "d";
const char str4[] PROGMEM = "e";  const char str5[] PROGMEM = "f";  const char str6[] PROGMEM = "g";  const char str7[] PROGMEM = "h";
const char str8[] PROGMEM = "i";  const char str9[] PROGMEM = "j";  const char str10[] PROGMEM = "k"; const char str11[] PROGMEM = "l";
const char str12[] PROGMEM = "m"; const char str13[] PROGMEM = "n"; const char str14[] PROGMEM = "o"; const char str15[] PROGMEM = "p";
const char str16[] PROGMEM = "q"; const char str17[] PROGMEM = "r"; const char str18[] PROGMEM = "s"; const char str19[] PROGMEM = "t";
const char str20[] PROGMEM = "u"; const char str21[] PROGMEM = "v"; const char str22[] PROGMEM = "w"; const char str23[] PROGMEM = "x";
const char str24[] PROGMEM = "y"; const char str25[] PROGMEM = "z";
const char str26[] PROGMEM = "0"; const char str27[] PROGMEM = "1"; const char str28[] PROGMEM = "2"; const char str29[] PROGMEM = "3";
const char str30[] PROGMEM = "4"; const char str31[] PROGMEM = "5"; const char str32[] PROGMEM = "6"; const char str33[] PROGMEM = "7";
const char str34[] PROGMEM = "8"; const char str35[] PROGMEM = "9";
const char str36[] PROGMEM = ","; const char str37[] PROGMEM = ".";  const char str38[] PROGMEM = "?"; const char str39[] PROGMEM = "!";
const char str40[] PROGMEM = ":"; const char str41[] PROGMEM = "\""; const char str42[] PROGMEM = "'"; const char str43[] PROGMEM = "=";
const char str44[] PROGMEM = "@"; const char str45[] PROGMEM = "_";  const char str46[] PROGMEM = "("; const char str47[] PROGMEM = ")";
const char str48[] PROGMEM = "^"; const char str49[] PROGMEM = "&";  const char str50[] PROGMEM = ";"; const char str51[] PROGMEM = "+";
// set up a table to refer to your strings.
const char* const strtable[] PROGMEM =
  str0, str1, str2, str3, str4, str5, str6, str7, str8, str9, str10, str11, str12, str13, str14, str15, str16, str17,
  str18, str19, str20, str21, str22, str23, str24, str25, str26, str27, str28, str29, str30, str31, str32, str33, str34,
  str35, str36, str37, str38, str39, str40, str41, str42, str43, str44, str45, str46, str47, str48, str49, str50, str51
// code strings // letters
const char code0[] PROGMEM = ".-";    const char code1[] PROGMEM = "-...";  const char code2[] PROGMEM = "-.-.";
const char code3[] PROGMEM = "-..";   const char code4[] PROGMEM = ".";     const char code5[] PROGMEM = "..-.";
const char code6[] PROGMEM = "--.";   const char code7[] PROGMEM = "....";  const char code8[] PROGMEM = "..";
const char code9[] PROGMEM = ".---";  const char code10[] PROGMEM = "-.-";  const char code11[] PROGMEM = ".-..";
const char code12[] PROGMEM = "--";   const char code13[] PROGMEM = "-.";   const char code14[] PROGMEM = "---";
const char code15[] PROGMEM = ".--."; const char code16[] PROGMEM = "--.-"; const char code17[] PROGMEM = ".-.";
const char code18[] PROGMEM = "...";  const char code19[] PROGMEM = "-";    const char code20[] PROGMEM = "..-";
const char code21[] PROGMEM = "...-"; const char code22[] PROGMEM = ".--";  const char code23[] PROGMEM = "-..-";
const char code24[] PROGMEM = "-.--"; const char code25[] PROGMEM = "--..";
// numbers
const char code26[] PROGMEM = "-----"; const char code27[] PROGMEM = ".----"; const char code28[] PROGMEM = "..---";
const char code29[] PROGMEM = "...--"; const char code30[] PROGMEM = "....-"; const char code31[] PROGMEM = ".....";
const char code32[] PROGMEM = "-...."; const char code33[] PROGMEM = "--..."; const char code34[] PROGMEM = "---..";
const char code35[] PROGMEM = "----.";
// punctuation
const char code36[] PROGMEM = "--..--"; const char code37[] PROGMEM = ".-.-.-"; const char code38[] PROGMEM = "..--..";
const char code39[] PROGMEM = "..--.";  const char code40[] PROGMEM = "---..."; const char code41[] PROGMEM = ".-..-.";
const char code42[] PROGMEM = ".----."; const char code43[] PROGMEM = "-...-";  const char code44[] PROGMEM = ".--.-.";
const char code45[] PROGMEM = "..-.--"; const char code46[] PROGMEM = "-.--.";  const char code47[] PROGMEM = "-.--.-";
const char code48[] PROGMEM = "..--";   const char code49[] PROGMEM = ".-...";  const char code50[] PROGMEM = "-.-.-.";
const char code51[] PROGMEM = ".-.-.";
const char* const codetable[] PROGMEM =
  code0, code1, code2, code3, code4, code5, code6, code7, code8, code9, code10, code11, code12, code13, code14, code15, code16, code17,
  code18, code19, code20, code21, code22, code23, code24, code25, code26, code27, code28, code29, code30, code31, code32, code33, code34,
  code35, code36, code37, code38, code39, code40, code41, code42, code43, code44, code45, code46, code47, code48, code49, code50, code51
char buffer[7]; // make sure this is large enough for the largest string it must hold
void setup()
  noTone(8);
  Serial.begin(baud);
  if (SDready)
      SDready = false;
      delay(3000);
    else
      Serial.println(F("SD card initialized.")); // if using a good terminal you'll never see this :-)
      SDready = true;
      countRootFiles(root, fileCount);
  refresh_Screen();
  Serial.println(Brag);
  menu();
  // code_chart();
void loop()
  parser();
void menu() {
  if (fileCount > 0)
    Serial.print(F(" SD files:")); Serial.print(fileCount);
  if (testStr != "")
  Serial.println();
void parser()
  do
  while (digits < 1);
  delay(key_wait);
  do
  Serial.flush();
  switch (keypress)
        random_code();
        break;
    case 'c': case 'C':
        break;
    case 'd': case 'D':
        refresh_Screen();
        code_chart();
        break;
    case 'f': case 'F':
          break;
        if (value > 0) {
          echo = true;
        else {
          echo = false;
        refresh_Screen();
        send_SDtext();
        break;
        if (value < 11)
        break;
    case 'l': case 'L': // send the letter characters
        shortRow();
          testStrRow = 26;
        break;
          refresh_Screen();
        menu();
        break;
    case 'n': case 'N': // send the number characters
        shortRow();
          testStrRow = 10;
        break;
    case 'p': case 'P':
        pitch = value;
        if (pitch == 0)
          pitch = 0;
          noTone(8);
          break;
          break;
        break;
        if (value == 0)
          if (testStr != "")
          break;
        if (testStr != "")
            testStrRow = value;
            break;
          else
            break;
          row = value;
          break;
        else
          break;
        break;
        testStrRow = 0;
        build_testStr();
        break;
        shortRow();
          testStrRow = 16;
        break;
        break;
  if (term == true)
    send_select();
    return;
    unsigned int randNumber = random(52); // 0 - 51, all characters.
    // see if the randNumber character is in string 'answers' already.
    getStr(randNumber); // in it's way, returns 'buffer' which is the char string pointed to by the index 'randNumber'
    if (answers.indexOf(buffer) != -1) t = t - 1; // character already in array. reject and try again
    else
    { // answer string is built fast (even 52 chars). no jerkyness so no need to build a code array to send
      answers.concat(buffer); answers.concat(" "); // add a space after each character for readability
      getCode(randNumber); // get the code string (.-..)
      send_code(buffer);
    unsigned int randNumber = random(testStr.length());
    else
        getStr(i);
        if (testStr.substring(randNumber, randNumber + 1) == buffer) // to index the correct code string
          getCode(i);
          send_code(buffer);
  if (error == 1)
    error = 0;
    return;
  Serial.flush();
  if (testStr == "")
    return;
    error = 1;
    testStr = "";
    return;
      error = 1;
      testStr = "";
      return;
      getStr(i);
      if (testStr.substring(s, s + 1) == buffer) // if a match is found for this char set a flag. don't check further
        error = 0;
        break;
      testStr = "";
      error = 1;
      return;
  Serial.flush();
      Serial.print(inChar);       // echo user input to screen
      Serial.println();
      return testStr;
    String x;
  letter_space();
  noTone(8);
  delay(elementWait);
void word_space() {
  testStrRow = 0;
  Serial.flush();
  delay(10);
    delay(10);
      Serial.println();
      return;
void code_chart()
  unsigned int i;
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
  getStr(i);
  Serial.print("["); Serial.print(buffer); Serial.print("]");
  getCode(i);
  Serial.print(buffer); Serial.print(" ");
void send_SDtext()
  String str; char fname[4]; // filename size up to 999, 1000 files. might be enough :-)
  str.toCharArray(fname, 4); // convert string to char array. Note char size (4). good to 999 files + 0. 1000 files
  if (dataFile)
      printChar = send_char;  // keep the cap letters for screen printout
          break;
          word_space();
          break;
        getStr(i);
        if (send_char == buffer) // if a match is found for this char, get code and send it
          getCode(i);
          send_code(buffer);
          break;
    dataFile.close();
    Serial.println();
    if (echo == false)
      dataFile.close();
    Serial.println();
void getStr(unsigned int i)
  strcpy_P(buffer, (char*)pgm_read_word(&(strtable[i])));
void getCode(unsigned int i)
  strcpy_P(buffer, (char*)pgm_read_word(&(codetable[i])));
unsigned int countRootFiles(File, unsigned int)
  File root;
  root = SD.open("/");
  root.rewindDirectory(); // Begin at the start of the directory
  while (true)
    File entry = root.openNextFile();
    if (! entry)
      break;
    fileCount++;                  // looks like count starts at the second file. this turns out not to be a problem. not sure why!
    if (fileCount > 999) fileCount = 999; // have to change array char string size for a bigger (4 digit) number
    entry.close();
  return fileCount;
//...actually...(to be continued)
flat5
Joined Nov 13, 2008
403
Could use some help. I've spent lots of time but have not yet solved these three problems.
To do:
resolve file 0/no file problem. checking user input when no input or an input of zero
find a way to stop writing an SD file without an EOF marker.
sort the SD file list in less than 2000 bytes
Sketch uses 30,314 bytes (93%) of program storage space. Maximum is 32,256 bytes.
Global variables use 1,114 bytes (54%) of dynamic memory, leaving 934 bytes for local variables. Maximum is 2,048 bytes. Edit: some bug fixes.
Code:
// Morse Receive Practice v2.8.2
// by flat5 June 15, 2015
// Plug speaker to Digital pin8 and Gnd. Use a resistor or pot in series if you want to. I used 220 ohms.
// version 2.6 is a rewrite of how static strings are stored. Only 51% of dynamic memory is used!
// Not tested beyond 64 yet! format to Fat32 & avoid 'too many files' error. array will not work with 4 digit numbers unless YOU change it
// v2.7 & v2.8 Some SD card options added. This ver, some code cleanup and a feature or two added.
// v2.8.a changed the behaviour of some options
// to do:
// resolve file 0/no file problem. find a way to stop writing an SD file without an EOF marker. sort the SD file list in less than 2000 bytes
#include <SPI.h>
#include <SD.h>
String Brag = "Morse Receive Practice v2.8.2 developed by Barry Block\n";
byte echo;
const unsigned long int baud = 115200; // *** 115200 57600 9600 300 2 make sure the terminal program matches!
byte ANSI = true; //false        // *** If you are not using an ANSI terminal program and the screen has weird characters
//                               //     at the beginning of some lines change this from true to false. now a menu item
unsigned int pitch = 830; //0    // *** 0 if using an oscillator, not tone(). You might want to use 600Hz, for example.
unsigned int soft = 950;         // *** find a pitch that is quieter in your setup
unsigned int key_wait = 0000;    // *** pause to give you time to enter data, in milliseconds. for slow typers (Ex. 0,1,2,3 in menu)
const byte signalPin = 13;       // *** will control oscillator speaker, if using external circuit. else connect sounder to D8
unsigned int row = 52;           // *** do NOT make this number larger or smaller than the array - 52!
unsigned int elementWait = 1200 / wpm; char keypress; unsigned int value; unsigned int Length; unsigned int fileCount = 0;
String sendfile = ""; String testStr; unsigned int testStrRow; String send_char; String answers; unsigned int flag = 0;
File root; String filename;
// numbers
// punctuation
void setup()
  noTone(8);
  Serial.begin(baud);
  if (SDready)
      SDready = false;
      delay(3000);
    else
      SDready = true;
  refresh_Screen();
  menu();
  // code_chart();
void loop()
  parser();
void menu() {
  Serial.println(F("p(value) adjust pitch, p off, p7 decrement 10Hz, p8 increment 10Hz, p9 soft (preset)"));
  if (SDready)
    Serial.println(F("x SD card menu"));
  Serial.println(F("n(row) send numbers"));
  Serial.println(F("l(row) send letters"));
  Serial.println(F("u(row) send punctuation characters or u77 (or >) to not send them"));
  Serial.println(F("c clear screen or to toggle this option: c(number)"));
  if (fileCount > 0)
  if (testStr != "")
  Serial.println();
void parser()
  getChars();
  switch (keypress)
        random_code();
        break;
    case 'c': // clear screen if ANSI is supported
        if (value > 0)
          if (ANSI == true) ANSI = false;
          else ANSI = true;
          break;
        refresh_Screen(); // an ANSI terminal is required for this to work
        break;
    case 'd': // display code chart
        refresh_Screen();
        code_chart();
        break;
    case 'f': // send random textfile from SD card
          break;
        if (value > 0) {
          echo = true;
        else {
          echo = false;
        refresh_Screen();
        send_SDtext();
        break;
    case 'k': // keypress timeout
        if (value < 11) key_wait = value * 1000;
        break;
    case 'l': // send the letter characters
        if (value == 0 ) testStrRow = 26;
        else testStrRow = value;
          testStrRow = 26;
        Serial.print(F("\nTestString set to letters. Characters to be sent:")); Serial.println(testStrRow);
        break;
    case 'm': case 'h': case '?': case 'i': // display menu
        if (keypress == 'i' || keypress == '?')
          refresh_Screen();
        menu();
        break;
    case 'n': // send the number characters
        if (value == 0 ) testStrRow = 10;
          testStrRow = 10;
        Serial.print(F("\nTestString set to numbers. Characters to be sent:")); Serial.println(testStrRow);
        break;
    case 'p': // pitch
        if (value == 7)
          pitch = pitch - 10;
          if (pitch > 24000 || pitch < 31) pitch = 31; // unsigned int rollover
          confirm_pitch();
          break;
        if (value == 8)
          pitch = pitch + 10;
          if (pitch > 24000) pitch = 24000;
          confirm_pitch();
          break;
        if (value == 9) // find a pitch that is much lower in volume than others
          pitch = soft;
          confirm_pitch();
          break;
        if (value == 0)
          pitch = 0;
          noTone(8);
          break;
        if (value < 31 || value > 24000)
          break;
        pitch = value;
        confirm_pitch();
        break;
    case 'r': // how many chars to send (a row)
        if (value == 0)
          if (testStr != "")
          break;
        if (testStr != "")
            testStrRow = value;
            break;
          else
            break;
          row = value;
          break;
        else
          break;
    case 's': // letter space time length (1 is same time as a dit)
        break;
    case 't': // send a selected group of characters
        testStrRow = 0;
        build_testStr();
        break;
    case 'u': // send the punctuation characters or not
        if (value > 76)
          testStr = "1234567890abcdefghijklmnopqrstuvwxyz";
          Serial.println(F("TestString set to numbers & letters"));
          testStrRow = 36;
          break;
        if (value == 0 ) testStrRow = 16;
          testStrRow = 16;
        Serial.print(F("Characters to be sent:")); Serial.println(testStrRow);
        break;
    case 'w': // wpm
        break;
    case 'x': // SD card sub menu
        SDfiles();
        break;
void refresh_Screen() // requires an ANSI terminal. can be toggled. see menu display
  if (ANSI == true)
void random_code() // send a random character's Morse equivalent and display answer. Heart of the program!
    send_select();
    return;
    else
      send_code(buffer);
    else
        getStr(i);
          getCode(i); // get char pointed to by i and return it as 'buffer'
          send_code(buffer);
  inString_build(); // collect chars and put in testStr if they are legal. if not, return flag 1
  if (flag == 1)
    flag = 0;
    return;
  Serial.flush();
  if (testStr == "")
    return;
    flag = 1;
    testStr = "";
    return;
    char h; h = char(testStr.charAt(t)); // overcoming the string vs char compile error by CASTING
    for (int i = t + 1; i < testStr.length(); i++)
      if (h == char(testStr.charAt(i)))
        flag = 1;
        testStr = "";
        return;
    flag = 1; // set the flag
      getStr(i);
        flag = 0;
        break;
    if (flag == 1) // illegal character. kill testStr and return. don't check rest of testStr.
      testStr = "";
      flag = 1;
      return;
  Serial.flush();
      Serial.println();
      return testStr;
    String x;
  letter_space();
  noTone(8);
  delay(elementWait);
void word_space() {
  testStrRow = 0;
  Serial.flush();
  delay(10);
    delay(10);
      Serial.println();
      return;
void code_chart()
  unsigned int i;
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
  getStr(i);
  getCode(i);
void send_SDtext()
  if (sendfile != "")
    str = sendfile; sendfile = ""; // a file has been specifically chosen
  if (dataFile)
          break;
          word_space();
          break;
        getStr(i);
          getCode(i);
          send_code(buffer);
          break;
    dataFile.close();
    Serial.println();
    if (echo == false)
      dataFile.close();
    Serial.println();
  fileCount = 0;
  File root;
  while (true)
    if (! entry)
      break;
    String n = entry.name();
    if (n.toInt() != 0 || n == "0") // only include files starting with a number BUT file 0 will not be displayed unless exception is made
      fileCount++;
    entry.close();
  return fileCount;
void SDfiles()
  if (flag == 0) refresh_Screen();
  Serial.println(F("\nChoose Option:\n"));
  Serial.println(F("l list files"));
  Serial.println(F("r(filenumber) read file"));
  Serial.println(F("s(filenumber) send file"));
  Serial.println(F("d(filenumber) delete file"));
  Serial.println(F("w(filenumber) write file"));
  Serial.println(F("t1 (Load testString) t2 (Save testString) t3 (Delete testString)"));
  Serial.println(F("x return to main menu"));
  flag = 0;
  getChars();
  refresh_Screen();
  switch (keypress) // char
    case 'd': // delete file
        if (value == 0)
          Serial.println(F("File 0 is protected so that it will not be deleted by mistake\n"));
          flag = 1; SDfiles();
          return;
        File root;
        char fname[4];
        filename = String(value);
        filename.toCharArray(fname, 4);
        if (SD.exists(fname))
          SD.remove(fname);
          Serial.print(F("File ")); Serial.print(fname); Serial.println(F(" Deleted."));
          root.close();
          return;
        else
          Serial.print(F("File ")); Serial.print(fname); Serial.println(F(" not found."));
        return;
    case 'l': // list SD root files
        printDirectory();
        return;
    case 'r': //read textfile
        char fname[4];
          refresh_Screen();
          Serial.print(F("File: ")); Serial.println(fname); Serial.println();
          dataFile.close();
          Serial.println();
        else
          Serial.println(F("\nfile not found"));
          Serial.println();
        return;
    case 's': // send textfile
        sendfile = String(value);
        byte e = echo;
        echo = true;
        send_SDtext(); // flag to echo the chars rather than show at the end
        echo = e;      // reset 'global' echo
        return;
    case 't': //teststring routines
        if (value < 1 || value > 3)
          Serial.println(F("\nNo such option. t1 load - t2 save - t3 delete"));
          return;
        File myFile;
        if (value == 1) // read file
          myFile = SD.open("/utility/t1");
          if (myFile)
            testStr = "";
            Serial.print(F("\nloading testStr: "));
            while (myFile.available()) // read from the file until there's nothing else in it
              char a = (myFile.read()); // read a char and add to testStr
              testStr = testStr + a;
            myFile.close(); // close the file
            Serial.println(testStr); Serial.println();
          else
            Serial.println(F("\nError opening /utility/t1\n")); // if the file didn't open, print an error
          return;
        else if (value == 2) // write file
          if (!SD.exists("test_str/"))
            SD.mkdir("test_str");
          SD.remove("/utility/t1");
          testStr.trim(); testStr.toLowerCase();
          myFile = SD.open("/utility/t1", FILE_WRITE);
          if (myFile) // if the file opened okay, write to it
            Serial.print(F("\nSaving testString: "));
            myFile.print(testStr); // write the string to the file
            testStrRow = testStr.length(); // store string length
          else
            Serial.println(F("error opening /utility/t1"));
          menu();
          return;
        else if (value == 3) // delete file
          delay(200); // just seemed like a good idea
          if (! SD.exists("/utility/t1")) Serial.println(F("testString file deleted\n"));
          menu();
          return;
    case 'w': // write textfile to SD card
        //value = 65; // test file for now
        if (value == 0)
          Serial.println(F("File 0 is protected so that it will not be altered by mistake")); // until a better solution is found
          return;
        char fname[4]; byte inChar; filename = String(value); unsigned int i = 0;
        File dataFile = SD.open(fname, FILE_WRITE);
        Serial.print(F("\nWaiting..."));
        delay(10);
        while (Serial.peek() < 1);
        Serial.println(F("OK, receiving data"));
        do
          if (Serial.peek() > 0)
            inChar = Serial.read(); if (inChar < 127) dataFile.write(inChar);
            i++; if (i > 150) Serial.print(F(".")); i = 0; // show something is happening
        } while (inChar != 129); // 129 this is the best I can come up with. use an unused ANSI char to break out of the loop
        //                       // batchfile 129.bat ( @echo  >>%1 ) puts ANSI char 129 at end of a textfile. Then upload it.
        dataFile.close();
        Serial.println(); Serial.print(F("Data saved as file ")); Serial.println(fname); Serial.println();
        Serial.flush(); delay(100);
        return;
    case 'x':
        menu();
        return;
    default:
        Serial.println(F("Error - not an option\n"));
        return;
void printDirectory()
  unsigned int i = 0;
  File root = SD.open("/");
  if (ANSI == true) Serial.println(F("File\tSize\t\tFile\tSize\t\tFile\tSize\t\tFile\tSize\t\tFile\tSize"));
  Serial.println();
  while (true)
    if (! entry) break;
      Serial.print(entry.name()); Serial.print("\t"); Serial.print(entry.size(), DEC); Serial.print("\t\t");
      i++;
      if (i > 4)
        Serial.println();
        i = 0;
    entry.close();
  root.close();
  Serial.println(); Serial.print(F("Files: ")); Serial.print(fileCount); Serial.println(); Serial.println();
void getChars()
  if (ANSI == true) Serial.print(F("<")); // It gives some indication that the prog has not crashed and is awaiting instructions
  value = 0;
  do // wait till a key is pressed
  } while (digits < 1); // 1 == a key press
  keypress = Serial.read(); if (keypress > 64 && keypress < 97) keypress = keypress + 32;
  delay(key_wait);
  do
  } while (digits < 0); // I do not understand this
  Serial.flush();
  if (ANSI == true) Serial.write(8); // backspace
void confirm_pitch()
flat5
Joined Nov 13, 2008
403
Sketch uses 31,500 bytes (97%) of program storage space. Maximum is 32,256 bytes.
Global variables use 1,129 bytes (55%) of dynamic memory, leaving 919 bytes for local variables. Maximum is 2,048 bytes.
Code:
// Morse Receive Practice v2.9
// by flat5 June 17, 2015
// v2.8.b added - and $ to the char* arrays. added array (size) variable to simplify adding new chars
// v2.9 adding a feature from Morse Machine. computer sends a char. you type the char correctly or computer sends it again
// to do:
#include <SPI.h>
#include <SD.h>
String Brag = "Morse Receive Practice v2.9 developed by Barry Block\n";
byte echo;
unsigned int loud = 750;         // *** find a pitch that is louder  in your setup
unsigned int array = 54;         //     total number of Morse characters
unsigned int row = array;        // *** do NOT make this number larger than the array!
const char str52[] PROGMEM = "-"; const char str53[] PROGMEM = "$";
  str35, str36, str37, str38, str39, str40, str41, str42, str43, str44, str45, str46, str47, str48, str49, str50, str51, str52, str53
// numbers
// punctuation
const char code45[] PROGMEM = "..--.-"; const char code46[] PROGMEM = "-.--.";  const char code47[] PROGMEM = "-.--.-";
const char code51[] PROGMEM = ".-.-.";  const char code52[] PROGMEM = "-....-"; const char code53[] PROGMEM = "...-..-";
  code35, code36, code37, code38, code39, code40, code41, code42, code43, code44, code45, code46, code47, code48, code49, code50, code51,
  code52, code53
char buffer[8]; // make sure this is large enough for the largest code string it must hold. $ == 7
void setup()
  noTone(8);
  Serial.begin(baud);
  if (SDready)
      SDready = false;
      delay(3000);
    else
      SDready = true;
  refresh_Screen();
  menu();
  // code_chart();
void loop()
  parser();
void menu() {
  Serial.println(F("p(value) adjust pitch, p off, p7 decrement 10Hz, p8 increment 10Hz, p9 soft (preset) p99 loud (preset)"));
  if (SDready)
  Serial.println(F("z computer sends a character, you press the correct keyboard key"));
  if (fileCount > 0)
  if (testStr != "")
  Serial.println();
void parser()
  getChars();
  switch (keypress)
        random_code();
        break;
        if (value > 0)
          else ANSI = true;
          break;
        break;
        refresh_Screen();
        code_chart();
        break;
          break;
        if (value > 0) {
          echo = true;
        else {
          echo = false;
        refresh_Screen();
        send_SDtext();
        break;
        break;
          testStrRow = 26;
        break;
          refresh_Screen();
        menu();
        break;
          testStrRow = 10;
        break;
    case 'p': // pitch
        if (value == 7)
          pitch = pitch - 10;
          confirm_pitch();
          break;
        if (value == 8)
          pitch = pitch + 10;
          confirm_pitch();
          break;
          pitch = soft;
          confirm_pitch();
          break;
        if (value == 99) // find a pitch that is much higher in volume than others
          pitch = 750;
          confirm_pitch();
          break;
        if (value == 0)
          pitch = 0;
          noTone(8);
          break;
          break;
        pitch = value;
        confirm_pitch();
        break;
        if (value == 0)
          Serial.print(F("row length (1-")); Serial.print(array); Serial.print(F(", presently ")); Serial.println(row);
          if (testStr != "")
          break;
        if (testStr != "")
            testStrRow = value;
            break;
          else
            break;
          row = value;
          break;
        else
          Serial.print(F("Too high a number!(1-")); Serial.println(array);
          break;
        break;
        testStrRow = 0;
        build_testStr();
        break;
        if (value > 76)
          testStrRow = 36;
          break;
        testStr = ",.?!:\"'=@_()^&;+-$";
        if (value == 0 ) testStrRow = 18;
        if (testStrRow > 18)
          Serial.println(F("1-18 characters!"));
          testStrRow = 18;
        break;
    case 'w': // wpm
        break;
        SDfilesMenu();
        break;
    case 'z':
        Morse_Machine();
    default: break;
  if (ANSI == true)
    send_select();
    return;
    unsigned int randNumber = random(array); // 0 - 51, all characters.
    else
    { // answer string is built fast (even 54 chars). no jerkyness so no need to build a code array to send
      send_code(buffer);
    else
      for (unsigned int i = 0; i < array; i++)
        getStr(i);
          send_code(buffer);
  if (flag == 1)
    flag = 0;
    return;
  Serial.flush();
  if (testStr == "")
    return;
  if (testStr.length() > array)       // is the string too long? larger than the array of Morse characters
    Serial.print(F("Max:")); Serial.print(array); Serial.println(F(" characters - TestString cleared"));
    flag = 1;
    testStr = "";
    return;
        flag = 1;
        testStr = "";
        return;
    for (unsigned int i = 0; i < array; i++) // check to see that the character is a known Morse char.
      getStr(i);
        flag = 0;
        break;
      testStr = "";
      flag = 1;
      return;
  Serial.flush();
      Serial.println();
      return testStr;
    String x;
  letter_space();
  noTone(8);
  delay(elementWait);
void word_space() {
  delay((elementWait * space * 2) + 1); // close enough, it's correct for the proper space of 3 times dit.
  testStrRow = 0;
  Serial.flush();
  delay(10);
    delay(10);
      Serial.println();
      return;
void code_chart()
  unsigned int i;
    print_line(i);
    print_line(i);
    print_line(i);
  for (i = 36; i < 45; i++) {
    print_line(i);
  for (i = 45; i < 54; i++) {
    print_line(i);
  getStr(i);
  getCode(i);
void send_SDtext()
  if (sendfile != "")
  if (dataFile)
      for (unsigned int i = 0; i < array; i++) // check to see that the character is a known Morse char or space
          break;
          word_space();
          break;
        getStr(i);
          getCode(i);
          send_code(buffer);
          break;
    dataFile.close();
    Serial.println();
    if (echo == false)
      dataFile.close();
    Serial.println();
  fileCount = 0;
  File root;
  while (true)
    if (! entry)
      break;
      fileCount++;
    entry.close();
  return fileCount;
void SDfilesMenu()
  Serial.flush();
  flag = 0;
  getChars();
  refresh_Screen();
        if (value == 0)
          flag = 1; SDfilesMenu();
          return;
        File root;
        char fname[4];
          SD.remove(fname);
          root.close();
          return;
        else
        return;
        printDirectory();
        return;
        char fname[4];
          refresh_Screen();
          while (dataFile.available()) Serial.write(dataFile.read());
          dataFile.close();
        else Serial.println(F("\nfile not found"));
        Serial.println();
        return;
        byte e = echo;
        echo = true;
        return;
          return;
        File myFile;
          if (myFile)
            testStr = "";
          else
          return;
          if (!SD.exists("utility/"))
            SD.mkdir("utility");
          else
          menu();
          return;
          menu();
          return;
        if (value == 0)
          return;
        delay(10);
        do
            i++;
            if (i > 150)
        dataFile.close();
        delay(100); Serial.flush(); delay(100);
        return;
    case 'x':
        menu();
        return;
    default:
        return;
  unsigned int i = 0;
  Serial.println();
  while (true)
    if (! entry) break;
      i++;
      if (i > 4)
        Serial.println();
        i = 0;
    entry.close();
  root.close();
void getChars()
  value = 0;
  keypress = Serial.read(); if (keypress > 64 && keypress < 97) keypress = keypress + 32; // upper to lower case
  delay(key_wait);
  do
  Serial.flush();
void Morse_Machine()
  refresh_Screen(); code_chart();
  Serial.println(F("Press Enter to quit"));
  String y; char x; String u; byte t; String k; unsigned int w; unsigned int j;
  w = wpm; wpm = 30; elementWait = 1200 / wpm;
  do
    if (testStr == "") // send any of the full array
      int z = random(array);
      getStr(z);
      y = buffer; // char to send
      getCode(z);
      u = buffer; // code equivalent
    else // send one of the teststring chars
      int z = random(testStr.length());
      y = testStr.substring(z, z + 1);
        getStr(i);
        if (y == buffer)
          getCode(i);
          u = buffer;
          break;
    while (k != "\r")
      send_code(u);
      Serial.flush();
      getChars();
      k = String(keypress);
      if (k == y) break;
      if (k == "\r")
        wpm = w; elementWait = 1200 / wpm;
        refresh_Screen(); menu();
        return;
  } while (k != "\r");
  return;
djsfantasi
Joined Apr 11, 2010
9,237
If any of your variables are in actuality static (as chipselect appears to be), you can use a #define to create an alias for the constant value, freeing up the storage used for the variable.
If any of your integer variables are always positive and will always have a value in the range of 0-255, you can use a data type of byte instead, saving a byte of memory.
I fear you will not save too much in this manner, but I offer it as a techbnique.
You can analyze your sketch by starting with an empty sketch, and adding your library includes, one at a time and note how much memory each one uses. Similarly, you can add in your code a piece or function at a time and note how much memory each uses (You will probably have to include stub functions for the sketch to compile) I think you may be surprised by what you find.
This will identify code/flash/EEPROM hogs. There may be cases where there is nothing you can do, but knowledge is power.
flat5
Joined Nov 13, 2008
403
Thank you, djsfantasi. Are you suggesting I change 'unsigned int' to byte, where ever I can?
I changed 'const int chipSelect = 4;' to 'byte chipSelect = 4;'
The compiled sketch became 4 bytes bigger.
I'll read about #define.
Well, here is what Aduino has to say:
"In general, the const keyword is preferred for defining constants and should be used instead of #define."
Just tried const byte chipSelect...
Result was the same as const int.
flat5
Joined Nov 13, 2008
403
I do need help with break, return, calling a function from a function.
My main loop is just a parser(). When the submenu SDfilesMenu() is called and I
stay there for a while calling it's routines the program gets unstable. Memory gets corrupted. I start to see wrong characters on screen and then it hangs. My guess is, the stack is being, what? corrupted, overloaded or something.
If someone would look and see how I'm using break and return maybe they could help me.
below line 730 where the routine starts.
Edit: Delete: Edit:
Break and return did not work to go back to a submenu/switch routine even if I nested the loop. Goto solved the problem. I'll try to explain.
void SDfilesMenu()
{ switch
case 'a' { print something; break;} <-- will not take me back to the top of SDfilesMenu()
using return does the same.
case 'a' { print something; SDfilesMenu();break; (or return) } will put me back to the top of the function but causes an instability. This may 'work' up to 13 times.
Goto label; does not require calling the function again and has no problem...yet.
Edit again: Maybe I should have wrapped all the case statements in while loops with a break at the end of each, or better, all the case statement in one while loop. I should try that but I'm happy with the label for now.
flat5
Joined Nov 13, 2008
403
This has the improved recalling of the function. Function starts at line 731 (or did).
Code:
// Morse Receive Practice v2.9b
// by flat5 June 20, 2015
// v.2.9a altered a routine that calls itself by using a label (goto) to improve stability
// v.2.9.b a few tweaks and corrections
// to do:
#include <SPI.h>
#include <SD.h>
String Brag = "Morse Receive Practice v2.9b developed by Barry Block\n";
const byte chipSelect = 4; // SD card select
byte echo;
// numbers
// punctuation
  code52, code53
void setup()
  noTone(8);
  Serial.begin(baud);
  if (SDready)
      SDready = false;
      delay(3000);
    else
      SDready = true;
  refresh_Screen();
  menu();
  // code_chart();
void loop()
  parser();
void menu() {
  if (SDready)
  if (fileCount > 0)
  if (testStr != "")
  Serial.println();
void parser()
  getChars();
  switch (keypress)
        random_code();
        break;
        if (value > 0)
          else ANSI = true;
          break;
        break;
        refresh_Screen();
        code_chart();
        break;
          break;
        if (value > 0) {
          echo = true;
        else {
          echo = false;
        refresh_Screen();
        send_SDtext();
        break;
        break;
          testStrRow = 26;
        break;
          refresh_Screen();
        menu();
        break;
          testStrRow = 10;
        break;
    case 'p': // pitch
        if (value == 7)
          pitch = pitch - 10;
          confirm_pitch();
          break;
        if (value == 8)
          pitch = pitch + 10;
          confirm_pitch();
          break;
          pitch = soft;
          confirm_pitch();
          break;
          pitch = 750;
          confirm_pitch();
          break;
        if (value == 0)
          pitch = 0;
          noTone(8);
          break;
          break;
        pitch = value;
        confirm_pitch();
        break;
        if (value == 0)
          if (testStr != "")
          break;
        if (testStr != "")
            testStrRow = value;
            break;
          else
            break;
          row = value;
          break;
        else
          break;
        break;
        testStrRow = 0;
        build_testStr();
        break;
        if (value > 76)
          testStrRow = 36;
          break;
          testStrRow = 18;
        break;
    case 'w': // wpm
        break;
        SDfilesMenu();
        break;
    case 'z':
        Morse_Machine();
    default: break;
  if (ANSI == true)
    send_select();
    return;
    else
      send_code(buffer);
    else
        getStr(i);
          send_code(buffer);
  if (flag == 1)
    flag = 0;
    return;
  Serial.flush();
  if (testStr == "")
    return;
    flag = 1;
    testStr = "";
    return;
        flag = 1;
        testStr = "";
        return;
      getStr(i);
        flag = 0;
        break;
      testStr = "";
      flag = 1;
      return;
  Serial.flush();
      Serial.println();
      return testStr;
    String x;
  letter_space();
  noTone(8);
  delay(elementWait);
void word_space() {
  testStrRow = 0;
  Serial.flush();
  delay(10);
    delay(10);
      Serial.println();
      return;
void code_chart()
  unsigned int i;
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
  getStr(i);
  getCode(i);
void send_SDtext()
  if (sendfile != "")
  if (dataFile)
          break;
          word_space();
          break;
        getStr(i);
          getCode(i);
          send_code(buffer);
          break;
    dataFile.close();
    Serial.println();
    if (echo == false)
      dataFile.close();
    Serial.println();
  fileCount = 0;
  File root;
  while (true)
    if (! entry)
      break;
      fileCount++;
    entry.close();
  return fileCount;
void SDfilesMenu()
label:
  while (Serial.available()) Serial.read();
  flag = 0;
  getChars();
  refresh_Screen();
        if (value == 0)
          flag = 1;
          goto label;
        File root;
        char fname[4];
          SD.remove(fname);
          root.close();
          goto label;
        else
        flag = 1;
        goto label;
        printDirectory();
        flag = 1;
        goto label;
        char fname[4];
          refresh_Screen();
          dataFile.close();
        Serial.println();
        flag = 1;
        goto label;
        byte e = echo;
        echo = true;
        flag = 1;
        goto label;
          flag = 1;
          goto label;
        File myFile;
          if (myFile)
            testStr = "";
          else
          flag = 1;
          goto label;
          else
          goto label;
          goto label;
        if (value == 0)
          flag = 1;
          goto label;
        delay(10);
        do
            i++;
            if (i > 150)
        dataFile.close();
        flag = 1;
        goto label;
    case 'x':
        menu();
        return;
    default:
        Serial.println(F("\nError - not an option\n"));
        flag = 1;
        goto label;
  unsigned int i = 0;
  Serial.println();
  while (true)
    if (! entry) break;
      i++;
      if (i > 4)
        Serial.println();
        i = 0;
    entry.close();
  root.close();
void getChars()
  value = 0;
  delay(key_wait); // we now have the option
  do               // collect the value if any
  } while (digits < 0); // I do not understand this. why not 1?
  Serial.flush();
  w = wpm; wpm = 25; elementWait = 1200 / wpm;
  do
      unsigned int z = random(array);
      getStr(z);
      getCode(z);
      unsigned int z = random(testStr.length());
        getStr(i);
        if (y == buffer)
          getCode(i);
          u = buffer;
          break;
    while (k != "\r")
      if (y == "_" || y == "^") break; // terminal progs I have tested have a problem with these characters
      send_code(u);
      Serial.flush();
      getChars();
      if (k == y) break;
      if (k == " ")
        Serial.print(F("answer is: ")); Serial.println(y);
      if (k == "\r")
        return;
  return;
flat5
Joined Nov 13, 2008
403
I want to add a Control Structure to the C++ language. what if ()
Sketch uses 31,252 bytes (96%) of program storage space. Maximum is 32,256 bytes.
Global variables use 1,136 bytes (55%) of dynamic memory, leaving 912 bytes for local variables. Maximum is 2,048 bytes.
Code:
// Morse Receive Practice v2.9c
// by flat5 June 21, 2015
// v2.9.c Morse Machine now does not repeat chars. sends string and makes a new one
// to do:
// resolve file 0/no file problem. find way to stop writing an SD file without EOF marker.
#include <Arduino.h>
#include <SPI.h>
#include <SD.h>
String Brag = "Morse Receive Practice v2.9c developed by Barry Block\n";
byte echo;
const char str44[] PROGMEM = "@"; const char str45[] PROGMEM = "-";  const char str46[] PROGMEM = "("; const char str47[] PROGMEM = ")";
const char str48[] PROGMEM = "$"; const char str49[] PROGMEM = "&";  const char str50[] PROGMEM = ";"; const char str51[] PROGMEM = "+";
const char str52[] PROGMEM = "_"; const char str53[] PROGMEM = "^";
// numbers
// punctuation
const char code45[] PROGMEM = "-....-";  const char code46[] PROGMEM = "-.--.";  const char code47[] PROGMEM = "-.--.-";
const char code48[] PROGMEM = "...-..-"; const char code49[] PROGMEM = ".-...";  const char code50[] PROGMEM = "-.-.-.";
const char code51[] PROGMEM = ".-.-.";   const char code52[] PROGMEM = "..--.-"; const char code53[] PROGMEM = "..--";
  code52, code53
void setup()
  pinMode(signalPin, OUTPUT);
  noTone(8);
  Serial.begin(baud);
  randomSeed(analogRead(0));
  if (SDready)
    Serial.println(F("Waking SD card"));
      SDready = false;
      delay(3000);
    else
      SDready = true;
  refresh_Screen();
  menu();
  // code_chart();
void loop()
  parser();
void menu() {
  Serial.println(F("Send a random group of characters for Morse practice"));
  if (SDready)
  if (fileCount > 0)
  if (testStr != "")
  Serial.println();
void parser()
  getChars();
  switch (keypress)
        random_code();
        break;
        if (value > 0)
          else ANSI = true;
          break;
        break;
        refresh_Screen();
        code_chart();
        break;
          break;
        if (value > 0) {
          echo = true;
        else {
          echo = false;
        refresh_Screen();
        send_SDtext();
        break;
        break;
          testStrRow = 26;
        break;
          refresh_Screen();
        menu();
        break;
          testStrRow = 10;
        break;
    case 'p': // pitch
        if (value == 7)
          pitch = pitch - 10;
          confirm_pitch();
          break;
        if (value == 8)
          pitch = pitch + 10;
          confirm_pitch();
          break;
          pitch = soft;
          confirm_pitch();
          break;
          pitch = 750;
          confirm_pitch();
          break;
        if (value == 0)
          pitch = 0;
          noTone(8);
          Serial.println(F("Tone off.")); // stare at the led or use an external oscillator triggered by pin D13
          break;
          Serial.println(F("Pitch range: 31-24000"));
          break;
        pitch = value;
        confirm_pitch();
        break;
        if (value == 0)
          if (testStr != "")
          break;
        if (testStr != "")
            testStrRow = value;
            break;
          else
            break;
          row = value;
          Serial.print(row); Serial.println(F(" characters will be sent"));
          break;
        else
          break;
        if (value != 0) space = value; // value 0 not allowed. just report setting
        break;
        testStrRow = 0;
        build_testStr();
        break;
        if (value > 76)
          if (value == 0 ) testStrRow = 36;
          if (testStrRow > 36)
            Serial.println(F("1-36 characters!"));
            testStrRow = 36;
          break;
          testStrRow = 18;
        break;
    case 'w': // wpm
        if (value != 0) wpm = value; // value 0 not allowed. just report setting
        elementWait = 1200 / wpm; // dit = 1200 / wpm
        break;
        SDfilesMenu();
        break;
    case 'z':
        Morse_Machine();
        break;
    default: break;
  if (ANSI == true)
    Serial.write(27);    // ESC
    Serial.write("[2J"); // clear screen
    Serial.write("[H");  // cursor to home
    send_select();
    return;
  for (unsigned int t = 0; t < row; t++) // each run will be 'row' characters (+ 'row' spaces)
    unsigned int randNumber = random(array); // 0 - 53, all characters.
    else
      send_code(buffer);
    else
        getStr(i);
          send_code(buffer);
  if (flag == 1)
    flag = 0;
    return;
  Serial.flush();
  if (testStr == "")
    return;
    flag = 1;
    testStr = "";
    return;
        flag = 1;
        testStr = "";
        return;
      getStr(i);
        flag = 0;
        break;
      testStr = "";
      flag = 1;
      return;
      Serial.println();
      return testStr;
    String x;
  letter_space();
void dit_dah(String x)
  digitalWrite(signalPin, HIGH);
  if (pitch != 0) tone(8, pitch);
  if (x == ".") delay(elementWait); // milliseconds - one dit
  else if (x == "-") delay(elementWait * 3);
  digitalWrite(signalPin, LOW);
  noTone(8);
  delay(elementWait);
void letter_space() {
  delay(elementWait * space);
void word_space() {
  testStrRow = 0;
  delay(10);
    delay(10);
      Serial.println();
      return;
void code_chart()
  unsigned int i;
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
    print_line(i);
  getStr(i);
  getCode(i);
void send_SDtext()
  if (sendfile != "")
  if (dataFile)
          break;
          word_space();
          break;
        getStr(i);
          getCode(i);
          send_code(buffer);
          break;
    dataFile.close();
    Serial.println();
    if (echo == false)
      dataFile.close();
    Serial.println();
  fileCount = 0;
  File root;
  while (true)
    if (! entry)
      break;
      fileCount++;
    entry.close();
  return fileCount;
void SDfilesMenu()
label:
  flag = 0;
  getChars();
  refresh_Screen();
        if (value == 0)
          flag = 1;
          goto label;
        File root;
        char fname[4];
          SD.remove(fname);
          root.close();
          goto label;
        else
        flag = 1;
        goto label;
        printDirectory();
        flag = 1;
        goto label;
        char fname[4];
          refresh_Screen();
          dataFile.close();
        Serial.println();
        flag = 1;
        goto label;
        byte e = echo;
        echo = true;
        flag = 1;
        goto label;
          flag = 1;
          goto label;
        File myFile;
          if (myFile)
            testStr = "";
          else
          flag = 1;
          goto label;
          else
          goto label;
          goto label;
        if (value == 0)
          flag = 1;
          goto label;
        delay(10);
        do
            i++;
            if (i > 150)
        dataFile.close();
        flag = 1;
        goto label;
    case 'x':
        menu();
        return;
    default:
        flag = 1;
        goto label;
  unsigned int i = 0;
  Serial.println();
  while (true)
    if (! entry) break;
      i++;
      if (i > 4)
        Serial.println();
        i = 0;
    entry.close();
  root.close();
void getChars()
  unsigned int digits;
  value = 0;
    digits = Serial.available();
  keypress = Serial.read(); if (keypress > 64 && keypress < 97) keypress = keypress + 32; //toLowerCase() is not for char
  delay(key_wait); // we now have the option (keypress)
  value = Serial.parseInt();
  Serial.flush();
  if (ANSI == true) Serial.write(8); // backspace. remove prompt '<'
  Serial.print(F("Tone pitch in Hz: ")); Serial.println(pitch, DEC);
  tone(8, pitch, 400); // give a sample
  byte w = wpm; wpm = 25; elementWait = 1200 / wpm; // store wpm. set wpm for this routine.
  String a; String c; String s; String k; byte flag = 0; unsigned int u;
label:
  if (testStr == "") // build string of all chars & set a flag to kill the string on exit
    flag = 1;
    for (unsigned int i = 0; i < array - 2; i++)         // problem with _ and ^ and keyboard input
      getStr(i);
      testStr = testStr + buffer;                        // string of chars to work with
  answers = "";
    else
  }                                                      // answers is testStr randomized. ready to send each char one at a time
  u = 0;
  while (true)
    if (u == testStr.length()) goto label;       // spent 2 days trying not to use goto. sorry I did. best way to get out of a nest
      a = answers.substring(u, u + 1);           // get and send a char
      getStr(i);
      if (a == buffer)
        s = buffer; // Morse char
        getCode(i);
        c = buffer; // Morse string
        while (true)
          send_code(c);
          getChars();
          if (k == s)
            u++;
            break;
          if (k == " ")
            Serial.print(F("answer is: ")); Serial.println(s);
          if (k == "\r")
            if (flag == 1)
              flag = 0;
              testStr = "";
            return;
flat5
Joined Nov 13, 2008
403
Code:
// Morse Receive Practice v2.9d
// by flat5 June 26, 2015
// choice of tone/noTone or external oscillator circuit triggered by pin13.
// Not tested beyond 98 yet! format to Fat32 & avoid 'too many files' error. array will not work with 4 digit numbers unless YOU change it
// v2.9.d New Morse Machine routine added for the punctuation characters. Send two of them 10 times each then add a third character.
// to do:
// resolve file 0/no file problem. find way to stop writing an SD file without EOF marker. or just move on to another program :-)
#include <SPI.h>
#include <SD.h>
const String Brag = "Morse Receive Practice v2.9d developed by Barry Block\n";
byte echo;
const unsigned int array = 54;   //     total number of Morse characters
unsigned int elementWait = 1200 / wpm; char keypress; unsigned int value; unsigned int fileCount = 0;
File root; String filename; String holdStr;
// numbers
// punctuation
  code52, code53
void setup()
  noTone(8);
  Serial.begin(baud);
  if (SDready)
      SDready = false;
      Serial.println(F("SD card not found"));
      delay(3000);
    else
      SDready = true;
  refresh_Screen();
  menu();
void loop()
  parser();
void menu() {
  Serial.println(F("r(value) adjust number of characters to send (row length: 1-54)"));
  Serial.println(F("t select characters to send (54 max) or just Enter to clear 'TestString'"));
  if (SDready)
  Serial.println(F("z(number) special routine to learn the puncuation characters"));
  if (fileCount > 0)
  if (testStr != "")
  Serial.println();
void parser()
  getChars();
  switch (keypress)
        random_code();
        break;
        if (value > 0)
          else ANSI = true;
          break;
        break;
        refresh_Screen();
        code_chart();
        break;
          break;
        if (value > 0) {
          echo = true;
        else {
          echo = false;
        refresh_Screen();
        send_SDtext();
        break;
        break;
          testStrRow = 26;
        break;
          refresh_Screen();
        menu();
        break;
          testStrRow = 10;
        break;
    case 'p': // pitch
        if (value == 7)
          pitch = pitch - 10;
          confirm_pitch();
          break;
        if (value == 8)
          pitch = pitch + 10;
          confirm_pitch();
          break;
          pitch = soft;
          confirm_pitch();
          break;
          pitch = 750;
          confirm_pitch();
          break;
        if (value == 0)
          pitch = 0;
          noTone(8);
          break;
          break;
        pitch = value;
        confirm_pitch();
        break;
        if (value == 0)
          if (testStr != "")
          break;
        if (testStr != "")
            testStrRow = value;
            break;
          else
            break;
          row = value;
          break;
        else
          break;
        Serial.print(F("Letter space time: ")); Serial.println(space);
        break;
        testStrRow = 0;
        build_testStr();
        break;
        if (value > 76)
            testStrRow = 36;
          break;
          testStrRow = 18;
        break;
    case 'w': // wpm
        Serial.print(F("wpm: ")); Serial.println(wpm);
        break;
        SDfilesMenu();
        break;
    case 'z':
        if (value > 0) flag = 2; // special case
        Morse_Machine();
        break;
    default: break;
  if (ANSI == true)
  if (testStr != "") // characters have been selected so just send them. Idea is to always use the Spacebar to send a test run
    send_select();
    return;
    else
    { // answer string is built fast (even 54 chars). no jerkyness so no need to pre-build a code array to send
      send_code(buffer);
void send_select() // called when testStr has proved legal
    else
      answers.concat(testStr[randNumber]); answers.concat(" "); // add a space after each character for readability
        getStr(i);
          send_code(buffer);
void build_testStr()   // Select characters for study (option t)
  if (flag == 1)
    flag = 0;
    return;
    Serial.print(F("TestString: ")); Serial.println(testStr);
void inString_build() // get chars from user and check them. if ok add them to testStr
  Serial.flush();
  Serial.println(F("Input characters & Enter to save a TestString or just Enter to clear the string.\n"));
  if (testStr == "")
    return;
  // now test the string for problems
    flag = 1;
    testStr = "";
    return;
  for (unsigned int t = 0; t < testStr.length(); t++) // check for duplicates
        flag = 1;
        testStr = "";
        return;
  for (unsigned int s = 0; s < testStr.length(); s++) // for each char of testStr...
      getStr(i);
        flag = 0;
        break;
      Serial.print(testStr.substring(s, s + 1));
      testStr = "";
      flag = 1;
      return;
String collect_chars(String testStr) // user input to build testStr
  delay(10); // seems to have removed the odd glitch
  while (Serial.available() < 1)
    if (inChar > 31 && inChar < 127)
      testStr = testStr + inChar; // screen gets filled with garbage without this check
    else if (inChar == '\r')
      Serial.println();
      return testStr;
  for (unsigned int i = 0; i < send_char.length(); i++) // break the Morse char string down to it's elements and send
    String x;
    x = send_char.substring(i, i + 1);
    dit_dah(x); // determine dit or dah and send
  letter_space();
void dit_dah(String x) // actually send the sounds
  noTone(8);
  delay(elementWait);
void letter_space() { // silence between chars
void word_space() {  // silence between words
  testStrRow = 0;
  delay(10);
    delay(10);
      Serial.println();
      return;
void code_chart() // show all Morse chars on screen
  unsigned int i;
  Serial.println(F("letters:"));
  for (i = 0; i < 13; i++) {
    print_line(i);
  } Serial.println(); Serial.println();
  for (i = 13; i < 26; i++) {
    print_line(i);
  Serial.println(F("numbers:"));
  for (i = 26; i < 36; i++) {
    print_line(i);
  Serial.println(F("punctuation:"));
    print_line(i);
    print_line(i);
void print_line(unsigned int i) // with the above to display chart
  getStr(i);
  getCode(i);
void send_SDtext() // send and show a random text file stored on the SD card
  if (sendfile != "")
  if (dataFile)
          break;
          word_space();
          break;
        getStr(i);
          getCode(i);
          send_code(buffer);
          break;
    dataFile.close();
    Serial.println();
    if (echo == false)
      dataFile.close();
    Serial.println();
void getStr(unsigned int i) // copy to buffer a string (one char) stored in flash memory (a)
void getCode(unsigned int i) // copy to buffer a string stored in flash memory (.-)
unsigned int countRootFiles(File, unsigned int) // get number of text files in SD root dir
  fileCount = 0;
  File root;
  while (true)
    if (! entry)
      break;
      fileCount++;
    entry.close();
  return fileCount;
void SDfilesMenu() // SD file options menu & routines
label:
  flag = 0;
  getChars();
  refresh_Screen();
        if (value == 0)
          flag = 1;
          goto label;
        File root;
        char fname[4];
          SD.remove(fname);
          root.close();
          goto label;
        else
        flag = 1;
        goto label;
        printDirectory();
        flag = 1;
        goto label;
        char fname[4];
          refresh_Screen();
          dataFile.close();
        Serial.println();
        flag = 1;
        goto label;
        byte e = echo;
        echo = true;
        flag = 1;
        goto label;
          flag = 1;
          goto label;
        File myFile;
          if (myFile)
            testStr = "";
          else
          flag = 1;
          goto label;
          else
          goto label;
          goto label;
        if (value == 0)
          flag = 1;
          goto label;
        delay(10);
        do
            i++;
            if (i > 150)
        dataFile.close();
        flag = 1;
        goto label;
    case 'x':
        menu();
        return;
    default:
        flag = 1;
        goto label;
void printDirectory() // display the names and size of the text files in SD root
  unsigned int i = 0;
  Serial.println();
  while (true)
    if (! entry) break;
      i++;
      if (i > 4)
        Serial.println();
        i = 0;
    entry.close();
  root.close();
void getChars() // get user input. option and value if any
  value = 0;
  Serial.flush();
void confirm_pitch() // play a sample of the new pitch
void Morse_Machine() // computer sends code, one char. user presses appropriate key
  holdStr = testStr; String a; String c; String s; String k; unsigned int u = 0; unsigned int v = 2; unsigned int x = 0;
label:
  if (flag > 0 ) // special handling of punctuation routine if selected - z(number)
    x++; // count chars sent
    String mmStr = ",.?!:\"'=@()&;+-$^_";
    testStr = mmStr.substring(0, v);
    if (x > v * 10) // each char sent 10 times
      v++;          // add another char to testStr
      x = 1;        // reset the test counter
      getStr(i);
  answers = "";
  for (unsigned int t = 0; t < testStr.length(); t++)    // random up the string to be sent
    else answers.concat(testStr[randNumber]);
  u = 0;
  while (true)
      getStr(i);
      if (a == buffer)
        getCode(i);
        while (true)                             // need a 'while' to break out of
          send_code(c);
          getChars();
          if (v > 18) k = "\r";         // we are done with the punctuation routine
          if (keypress == 126) k = "^"; // special keyboard/terminal problem with ^ & _
          if (keypress == 127) k = "_"; // don't know why. just happy I found this
          if (k == s)                   // correct user input. send another char
            u++; x++;
            break;
          if (k == " ")                 // hint, and not too subtle :-)
          if (k == "\r")                // cleanup, quit and return to parser()
            flag = 0;
            testStr = holdStr;
            return;
flat5
Joined Nov 13, 2008
403
Some code re-arranged as suggested by djsfantasi.
It has taken me time to understand some of his points.
Added a good routine for those who do not as yet know the code.
Sketch uses 31,840 bytes (98%) of program storage space. Maximum is 32,256 bytes.
Global variables use 1,164 bytes (56%) of dynamic memory, leaving 884 bytes for local variables. Maximum is 2,048 bytes.
Code:
// Morse Receive Practice v2.9e
// by flat5 June 27, 2015
// A few more punctuation characters added. Added a feature or two. Caught a few unwanted features.
// v2.9.d New Morse Machine routine added for the punctuation characters. Send two of them 10 times each then add a third character...
// v2.9.e generalize Morse Machine 'add a char' for letters, numbers, punctuation. some code cleanup
// to do:
// resolve file 0/no file problem or just move on to another program :-)
#include <SPI.h>
#include <SD.h>
const String Brag = "Morse Receive Practice v2.9e developed by Barry Block\n";
byte echo;
//                               //     It's good to send characters faster than the space between them for practice.
unsigned int wpm = 20;           // *** Change this to any default value
File root; String filename; String holdStr; unsigned int mmRepete = 10;
// numbers
// punctuation
  code52, code53
void setup()
  noTone(8);
  Serial.begin(baud);
  if (SDready)
      SDready = false;
      delay(3000);
    else
      SDready = true;
  refresh_Screen();
  menu();
void loop()
  parser();
void menu() {
  Serial.println(F("Press Spacebar to start test\n"));
  Serial.println(F("s(value) adjust letter spacetime (1-255)"));
  Serial.println(F("k(value) adjust keypress timeout in seconds(0-10)"));
  Serial.println(F("w(value) adjust wpm (Example: w20)"));
  if (SDready)
  Serial.println(F("z computer sends a character, you press the corresponding key"));
  Serial.println(F("z(number) for those who do not yet know the code. z1(letters) z2(numbers) z3(punctuation) z>3(# of repeats)"));
  Serial.println(F("d show Morse code chart"));
  Serial.println(F("m display this menu"));
  Serial.print(F("Currently: s:")); Serial.print(space); Serial.print(F(" k:")); Serial.print(key_wait / 1000);
  Serial.print(F(" zRepete:")); Serial.print(mmRepete);
  if (fileCount > 0)
    Serial.print(F(" SDfiles:")); Serial.print(fileCount);
  if (testStr != "")
    Serial.print(F(" TestString row:")); Serial.print(testStrRow); Serial.print(F(" TestString: ")); Serial.print(testStr);
  Serial.println();
void parser()
  getChars();
  switch (keypress)
    case ' ': // Spacebar. generate & send code
        random_code();
        break;
        if (value > 0)
          else ANSI = true;
          break;
        break;
        refresh_Screen();
        code_chart();
        break;
          break;
        if (value > 0) echo = true;
        else echo = false;
        refresh_Screen();
        send_SDtext();
        break;
        Serial.print(F("KeyWait: ")); Serial.println(key_wait / 1000);
        break;
        testStr = "abcdefghijklmnopqrstuvwxyz";
        if (testStrRow > 26)
          Serial.println(F("1-26 characters!"));
          testStrRow = 26;
        break;
          refresh_Screen();
        menu();
        break;
        testStr = "1234567890";
        if (testStrRow > 10)
          Serial.println(F("1-10 characters!"));
          testStrRow = 10;
        break;
    case 'p': // pitch
        if (value == 7)
          pitch = pitch - 10;
          confirm_pitch();
          break;
        if (value == 8)
          pitch = pitch + 10;
          confirm_pitch();
          break;
          pitch = soft;
          confirm_pitch();
          break;
          pitch = 750;
          confirm_pitch();
          break;
        if (value == 0)
          pitch = 0;
          noTone(8);
          break;
          break;
        pitch = value;
        confirm_pitch();
        break;
        if (value == 0)
          if (testStr != "")
            Serial.print(F("TestString row length: ")); Serial.println(testStrRow);
          break;
        if (testStr != "")
          if (value <= testStr.length())
            testStrRow = value;
            Serial.print(testStrRow); Serial.println(F(" characters will be sent while using current TestString"));
            break;
          else
            Serial.print(F("Too high a number! TestString is only ")); Serial.print(testStr.length()); Serial.println(F(" characters."));
            break;
        else if (value < 55)
          row = value;
          break;
        else
          break;
        break;
        testStrRow = 0;
        build_testStr();
        break;
        if (value > 76)
            testStrRow = 36;
          break;
        Serial.print(F("TestString set to puncuation characters: ")); Serial.println(testStr);
          testStrRow = 18;
        break;
    case 'w': // wpm
        break;
        SDfilesMenu();
        break;
    case 'z':
        if (value > 3)
          mmRepete = value;
          Serial.print(F("Will repete ")); Serial.print(mmRepete); Serial.println(F(" times before adding next character"));
          break;
        flag = value;
        Morse_Machine();
        break;
    default: break;
  if (ANSI == true)
    send_select();
    return;
    else
      send_code(buffer);
  if (testStrRow == 0) testStrRow = testStr.length();
  for (unsigned int t = 0; t < testStrRow; t++) // random up the string to be sent
    else
        getStr(i);
          send_code(buffer);
  Serial.println(answers); answers = ""; // display test answers and clear the string for the next run
  if (flag == 1)
    flag = 0;
    return;
  if (testStr != "")   // testStr is legal
  Serial.flush();
  testStr = collect_chars(testStr); //get user input
  if (testStr == "")
    Serial.println(F("TestString cleared"));
    return;
    flag = 1;
    testStr = "";
    return;
        Serial.println(F("Repeated character! - TestString cleared"));
        flag = 1;
        testStr = "";
        return;
      getStr(i);
        flag = 0;
        break;
      Serial.println(F(" is not a character in the Morse array. TestSring cleared"));
      testStr = "";
      flag = 1;
      return;
      Serial.println();
      return testStr;
    String x;
  letter_space();
  noTone(8);
  delay(elementWait);
void shortRow() // row length for the users input test string
  testStrRow = 0;
  Serial.println(F("Input how many characters to send or just Enter to send all"));
  delay(10);
    delay(10);
    if (inChar > 47 && inChar < 58)
      inString = inString + inChar; // if a number add to string
      testStrRow = inString.toInt();
      Serial.println();
      return;
  Lchart();
  Nchart();
  Pchart();
  getStr(i);
  getCode(i);
void Lchart()
  for (unsigned int i = 0; i < 13; i++) {
    print_line(i);
  for (unsigned int i = 13; i < 26; i++) {
    print_line(i);
void Nchart()
  for (unsigned int i = 26; i < 36; i++) {
    print_line(i);
void Pchart()
  for (unsigned int i = 36; i < 45; i++) {
    print_line(i);
  for (unsigned int i = 45; i < 54; i++) {
    print_line(i);
  if (sendfile != "")
  if (dataFile)
          break;
          word_space();
          break;
        getStr(i);
          getCode(i);
          send_code(buffer);
          break;
    dataFile.close();
    Serial.println();
    if (echo == false)
      dataFile.close();
    Serial.println();
  fileCount = 0;
  File root;
  while (true)
    if (! entry)
      break;
    if (n.toInt() != 0 || n == "0")//only include files starting with a number BUT file 0 will not be displayed unless exception is made
      fileCount++;
    entry.close();
  return fileCount;
label:
  flag = 0;
  getChars();
  refresh_Screen();
        if (value == 0)
          flag = 1;
          goto label;
        File root;
        char fname[4];
          SD.remove(fname);
          root.close();
          goto label;
        else
        flag = 1;
        goto label;
        printDirectory();
        flag = 1;
        goto label;
        char fname[4];
          refresh_Screen();
          dataFile.close();
        Serial.println();
        flag = 1;
        goto label;
        byte e = echo;
        echo = true;
        flag = 1;
        goto label;
          flag = 1;
          goto label;
        File myFile;
          if (myFile)
            testStr = "";
          else
          flag = 1;
          goto label;
          else
          goto label;
          goto label;
        if (value == 0)
          flag = 1;
          goto label;
        delay(10);
        do
            i++;
            if (i > 150)
        dataFile.close();
        flag = 1;
        goto label;
    case 'x':
        menu();
        return;
    default:
        flag = 1;
        goto label;
  unsigned int i = 0;
  Serial.println();
  while (true)
    if (! entry) break;
      i++;
      if (i > 4)
        Serial.println();
        i = 0;
    entry.close();
  root.close();
  value = 0;
  Serial.flush();
  refresh_Screen(); //code_chart();
  Serial.println(F("Press Enter to quit\n\n"));
  holdStr = testStr; String mmStr; String a; String c; String s; String k; unsigned int u = 0; unsigned int v = 2; unsigned int x = 0;
  if (flag == 1) {
    mmStr = "abcdefghijklmnopqrstuvwxyz";
    Lchart();  // show relavent part of code_chart()
  if (flag == 2) {
    mmStr = "1234567890";
    Nchart();
  if (flag == 3) {
    Pchart();
  if (testStr == "" && flag == 0)   // build string of all chars
    code_chart();
      getStr(i);
label:
  if (flag > 0 ) // special handling of routine if selected - z(number)
    if (x > v * mmRepete) // each char sent 'mmRepete' times. default is 10
  answers = "";
    if (answers.indexOf(testStr[randNumber]) != -1) t--; // character already in array. try again
  u = 0;
  while (true)
      getStr(i);
      if (a == buffer)
        getCode(i);
          send_code(c);
          getChars();
          if (v > 18) k = "\r";         // we are done with the beginner routine
            u++; x++;
            break;
            flag = 0;
            testStr = holdStr;
            return;
flat5
Joined Nov 13, 2008
403
Added a Help textfile option using the SD card. Had to alter some print statements to free up 200 bytes :)
Added a bookmark option to routines z1, z2, z3.
Spent a few hours trying to fix a routine in the program. Turned out to be rare problem with the SD tf card! Helpfile updated.
Code:
// Morse Receive Practice v3
// by flat5 July 1, 2015
// UK/US characters only
// v2.5 added SD card. randomly chooses textfile to send as Morse
// v2.9.f strings, letters, numbers, punctuation now const strings.
//        at this point I'd be better off moving some strings back to dynamic memory
//        more string cleanup to get room for an SD card Help text file routine.
// v3     added bookmark to z1 z2 z3 routine. continue where you left off
// Sketch uses 32,086 bytes (99%) of program storage space. Maximum is 32,256 bytes.
// Global variables use 1,236 bytes (60%) of dynamic memory, leaving 844 bytes for local variables. Maximum is 2,048 bytes.
#include <SPI.h>
#include <SD.h>
const String Brag = "Morse Receive Practice v3 developed by Barry Block\n";
const String letters = "abcdefghijklmnopqrstuvwxyz";
const String numbers = "1234567890";
const String punctuation = ",.?!:\"'=@_()^&;+-$";
byte echo;
char* hfile = "/utility/MRP_Help.txt"; // *** a Help text file. Put it on the SD card using this suggested folder/name.
unsigned int pitch = 570; //0    // *** 0 if using an oscillator, not tone(). You might want to use 600Hz, for example.
unsigned int soft = 620;         // *** find a pitch that is quieter in your setup
unsigned int loud = 740;         // *** find a pitch that is louder  in your setup
unsigned int space = 3;          // *** Default time between Morse characters.
String sendfile; String testStr; unsigned int testStrRow; String send_char; String answers; unsigned int flag = 0;
File root; String filename; String holdStr; unsigned int mmRepeat = 5; const String c = "Characters to be sent:";
const char str0[] PROGMEM = "a";  const char str1[] PROGMEM = "b";  const char str2[] PROGMEM = "c";  const char str3[] PROGMEM = "d";
const char str4[] PROGMEM = "e";  const char str5[] PROGMEM = "f";  const char str6[] PROGMEM = "g";  const char str7[] PROGMEM = "h";
const char str8[] PROGMEM = "i";  const char str9[] PROGMEM = "j";  const char str10[] PROGMEM = "k"; const char str11[] PROGMEM = "l";
const char str12[] PROGMEM = "m"; const char str13[] PROGMEM = "n"; const char str14[] PROGMEM = "o"; const char str15[] PROGMEM = "p";
const char str16[] PROGMEM = "q"; const char str17[] PROGMEM = "r"; const char str18[] PROGMEM = "s"; const char str19[] PROGMEM = "t";
const char str20[] PROGMEM = "u"; const char str21[] PROGMEM = "v"; const char str22[] PROGMEM = "w"; const char str23[] PROGMEM = "x";
const char str24[] PROGMEM = "y"; const char str25[] PROGMEM = "z";
const char str26[] PROGMEM = "0"; const char str27[] PROGMEM = "1"; const char str28[] PROGMEM = "2"; const char str29[] PROGMEM = "3";
const char str30[] PROGMEM = "4"; const char str31[] PROGMEM = "5"; const char str32[] PROGMEM = "6"; const char str33[] PROGMEM = "7";
const char str34[] PROGMEM = "8"; const char str35[] PROGMEM = "9";
const char str36[] PROGMEM = ","; const char str37[] PROGMEM = ".";  const char str38[] PROGMEM = "?"; const char str39[] PROGMEM = "!";
const char str40[] PROGMEM = ":"; const char str41[] PROGMEM = "\""; const char str42[] PROGMEM = "'"; const char str43[] PROGMEM = "=";
// numbers
// punctuation
  code52, code53
void setup()
  noTone(8);
  Serial.begin(baud);
  if (SDready)
    if (!SD.begin(chipSelect))
      SDready = false;
      Serial.println(F("no SD card"));
      delay(3000);
    else
      SDready = true;
  refresh_Screen();
  menu();
void loop()
  parser();
void menu() {
  Serial.println(F("s(value) set letter spacetime (1-255)"));
  Serial.println(F("k(value) set keypress timeout in seconds(0-10)"));
  Serial.println(F("w(value) set wpm (Example: w20)"));
  Serial.println(F("p(value) set pitch, p off, p7 decrement 10Hz, p8 increment 10Hz, p9 soft (preset) p99 loud (preset)"));
  Serial.println(F("r(value) set number of characters to send (row length: 1-54)"));
  Serial.println(F("t enter characters to send (54 max) or just Enter to clear 'TestString'"));
  if (SDready)
    Serial.println(F("f send a textfile from SD card. add number for text echo (f4)"));
    Serial.println(F("x SDcard menu"));
    Serial.println(F("h show helpfile"));
  Serial.println(F("z computer sends testString character, you press corresponding key"));
  Serial.println(F("u(row) send punctuation characters or u77 to not send them"));
  Serial.println(F("m display this menu - i clear screen first"));
  Serial.print(F(" w:")); Serial.print(wpm); Serial.print(F(" P:")); Serial.print(pitch); Serial.print(F(" r:")); Serial.print(row);
  Serial.print(F(" Zrepeat:")); Serial.print(mmRepeat);
  if (fileCount > 0)
  if (testStr != "")
  Serial.println();
void parser()
  getChars();
  switch (keypress)
        random_code();
        break;
        if (value > 0)
          else ANSI = true;
          break;
        break;
        refresh_Screen();
        code_chart();
        break;
        else echo = false;
        refresh_Screen();
        send_SDtext();
        break;
    case 'h': case '?':
        if (SD.exists(hfile)) // display /utility/MRP_Help.txt
          File dataFile = SD.open(hfile, FILE_READ);
          dataFile.close();
        else
          Serial.println(); Serial.print(hfile); Serial.println(F(" not found\n"));
        break;
        break;
        testStr = letters;
        if (testStrRow == 0 || testStrRow > 26) testStrRow = 26;
        if (value > 0) testStrRow = value;
          testStrRow = 26;
        Serial.print(F("\nTestString set to letters. ")); Serial.println(c + testStrRow);
        break;
    case 'm': case 'i': // display menu
          refresh_Screen();
        menu();
        break;
        testStr = numbers;
        if (testStrRow == 0 || testStrRow > 10) testStrRow = 10;
          testStrRow = 10;
        Serial.print(F("\nTestString set to numbers. ")); Serial.println(c + testStrRow);
        break;
    case 'p': // pitch
        if (value == 7)
          pitch = pitch - 10;
          confirm_pitch();
          break;
        if (value == 8)
          pitch = pitch + 10;
          confirm_pitch();
          break;
          pitch = soft;
          confirm_pitch();
          break;
          pitch = 750;
          confirm_pitch();
          break;
        if (value == 0)
          pitch = 0;
          noTone(8);
          break;
          break;
        pitch = value;
        confirm_pitch();
        break;
        if (value == 0)
          if (testStr != "")
          break;
        if (testStr != "")
            testStrRow = value;
            break;
          else
            break;
        else if (value <= array)
          row = value;
          Serial.println(c + row);
          break;
        else
          break;
        Serial.print(F("Letter space: ")); Serial.println(space);
        break;
        testStrRow = 0;
        build_testStr();
        break;
        if (value > 76)
          testStr = numbers + letters;
          if (testStrRow == 0 || testStrRow > 36) testStrRow = 36;
            testStrRow = 36;
          break;
        testStr = punctuation;
        if (testStrRow == 0 || testStrRow > 18) testStrRow = 18;
          testStrRow = 18;
        break;
    case 'w': // wpm
        break;
        SDfilesMenu();
        break;
    case 'z':
        if (value > 3)
          mmRepeat = value;
          Serial.print(F("Will repeat ")); Serial.print(mmRepeat); Serial.println(F(" times before adding next character"));
          break;
        flag = value;
        Morse_Machine();
        break;
    default: break;
  if (ANSI == true)
    send_select();
    return;
    else
      send_code(buffer);
  Serial.println(answers); answers = ""; // show test answers and clear string
    else
        getStr(i);
          send_code(buffer);
  if (flag == 1)
    flag = 0;
    return;
  //Serial.flush();
  Serial.println(F("Input characters & Enter to save a TestString or just Enter to clear the string."));
  if (testStr == "")
    return;
    flag = 1;
    testStr = "";
    return;
        flag = 1;
        testStr = "";
        return;
      getStr(i);
        flag = 0;
        break;
      testStr = "";
      flag = 1;
      return;
  testStr = ""; char inChar;
      Serial.println();
      return testStr;
void send_code(String send_char) // send the dits & dahs of the Morse string - codes[](Ex. .-..)
    String x;
  letter_space();
  noTone(8);
  delay(elementWait);
  char inChar; String inString;
  testStrRow = 0;
  delay(10);
    delay(10);
      Serial.println();
      return;
  Lchart();
  Nchart();
  Pchart();
void Lchart()
    print_line(i);
  } Serial.println(F("\n"));
    print_line(i);
void Nchart()
    print_line(i);
void Pchart()
    print_line(i);
    print_line(i);
  getStr(i); Serial.print("["); Serial.print(buffer); Serial.print("]");
  getCode(i); Serial.print(buffer); Serial.print(" ");
  unsigned int rand = random(fileCount);
  str = String(rand);        // convert int to string
  if (sendfile != "")
  str.toCharArray(fname, 4); // convert string to char array. Note char size (4). good to 1000 files plus string terminator
  Serial.print(F("textfile: ")); Serial.println(fname); Serial.println();
  File dataFile = SD.open(fname, FILE_READ);
  // if the file is available, READ from it.
  // This routine is fast enough that >3000 wpm seems to be sent with no jerkyness.
  if (dataFile)
    String send_char; int SDint; String printChar;
      SDint = dataFile.read();
      char c = char(SDint);   // int to char
      send_char = String(c);  // char to string
      send_char.toLowerCase();
        if (send_char < " " || send_char > "z")
          break;
        if (send_char == " ")
          word_space();
          break;
        getStr(i);
          getCode(i);
          send_code(buffer);
          break;
      if (echo == true) Serial.print(printChar); // It's fun to see the text as the code is being sent.
    dataFile.close();
    Serial.println();
    if (echo == false)
      dataFile.close();
    Serial.println();
  else // if the file isn't open, pop up an error:
    Serial.print(F("error opening ")); Serial.println(fname);
  fileCount = 0;
  File root;
  while (true)
    if (! entry)
      break;
    if (n.toInt() != 0 || n == "0") //only include files starting with number BUT file 0 will not display unless exception is made
      fileCount++;
    entry.close();
  return fileCount;
label:
  while (Serial.available()) Serial.read(); // have to make sure buffer is empty. options were being chosen!
  flag = 0;
  Serial.println();
  getChars();
  refresh_Screen();
        if (value == 0)
          Serial.println(F("File 0 protected\n"));
          flag = 1;
          goto label;
        File root;
        char fname[4];
          SD.remove(fname);
          root.close();
          countRootFiles(root, fileCount);
          goto label;
        else
        flag = 1;
        goto label;
        printDirectory();
        flag = 1;
        goto label;
        refresh_Screen();
        char fname[4];
          dataFile.close();
        else Serial.println(F("\nfile not found\n"));
        flag = 1;
        goto label;
        byte e = echo;
        echo = true;   // flag to echo the chars rather than show at the end
        send_SDtext();
        flag = 1;
        goto label;
          Serial.println(F("\nNo such option"));
          flag = 1;
          goto label;
        File myFile;
          if (myFile)
            testStr = "";
            Serial.print(F("\nloading testStr"));
          else
          flag = 1;
          goto label;
          if (!SD.exists("utility/")) SD.mkdir("utility");
            Serial.println(F("\nSaving testString"));
          else
          flag = 1;
          goto label;
          delay(100); // just seemed like a good idea
          if (! SD.exists("/utility/t1")) Serial.println(F("file deleted\n"));
          flag = 1;
          goto label;
        if (value == 0)
          Serial.println(F("File 0 protected")); // until a better solution is found
          flag = 1;
          goto label;
        delay(10);
        Serial.println(F("receiving data"));
        do
            i++;
            if (i > 150)
              Serial.print("."); i = 0; // show something is happening
        dataFile.close();
        Serial.print(F("\nFile saved as ")); Serial.println(fname);
        flag = 1;
        goto label;
    case 'x':
        menu();
        return;
    default:
        flag = 1;
        goto label;
  unsigned int i = 0;
  root.rewindDirectory(); // Begin at the start of the directory
  Serial.println();
  while (true)
    File entry = root.openNextFile();
    if (! entry) break;
      Serial.print(entry.name()); Serial.print(F("\t")); Serial.print(entry.size(), DEC); Serial.print(F("\t\t"));
      i++;
      if (i > 4)
        Serial.println();
        i = 0;
    entry.close();
  root.close();
  Serial.print(F("\r\n\nFiles: ")); Serial.println(fileCount);
  if (ANSI == true) Serial.print("<"); // It gives some indication that the prog has not crashed and is awaiting instructions
  value = 0;
  Serial.print("Tone pitch in Hz: "); Serial.println(pitch, DEC);
  String fname = "/utility/mmData" + String(flag); // len 17 including 0 at end
  char f[17];               // without the *
  fname.toCharArray(f, 17); // this took a day to get right
  if (flag > 0 && flag < 4 && SDready)
    if (SD.exists(f)) // load bookmark for z1, z2, z3 routine
      File dataFile = SD.open(f, FILE_READ);
      byte buf[2];
      for (unsigned int i = 0; i < 2; i++) buf[i] = dataFile.read();
      v = buf[0]; x = buf[1];
      dataFile.close();
  refresh_Screen();
  Serial.println(F("Press Enter to quit\n"));
  if (flag == 1) {
    mmStr = letters;
    Lchart();  // show relevent part of code_chart()
  if (flag == 2) {
    mmStr = numbers;
    Nchart();
  if (flag == 3) {
    mmStr = punctuation;
    Pchart();
    code_chart();
      getStr(i);
label:
    if (x > v * mmRepeat) // each char sent 'mmRepeat' times. default is 5
  answers = "";
    unsigned int randNumber = random(testStr.length());
  u = 0;                                                 // u is char position in answer string
  while (true)                                           // k == s so get next char to send
      getStr(i);
      if (a == buffer)
        getCode(i);
          send_code(c);
          getChars();
            u++; x++;
            break;
            Serial.print(F("answer: ")); Serial.println(s);
          if (k == "\r")                // cleanup, save some data, quit and return to parser()
            if (SDready && flag > 0)
              Serial.println(F("\nBookmark: Save y/n - Delete d"));
              getChars();
              switch (keypress)
                case 'd':
                    SD.remove(f); // if file does not exist, who cares?
                    break;
                case 'y':
                    SD.remove(f);
                    File dataFile = SD.open(f, FILE_WRITE);
                    dataFile.write(v); dataFile.write(x);  // not much of a file but if you just spent an hour taking the test...
                    dataFile.close();
                    break;
            flag = 0;
            testStr = holdStr;
            return;
Change extension of 129.txt to .bat
