Arduino single phase VFD
memaier
Joined Feb 10, 2017
Hello Everyone,
I’m a retired USAF Lt Col 25 years in service and 20 years as Industrial Electrician. I have always tinkered with electronics but this project is above my pay grade. I need some help. I have a single phase 120v 60Hz ¾ HP drill press I wish to convert to a homemade VFD controlled by Arduino. I found this circuit on http://www.homemade-circuits.com/2013/09/single-phase-variable-frequency-drive.html. Please see attached image.VFD.png
With my limited understanding of what is happening here, I think everything to the left of the4017 (IC3) can be replaced with the Arduino. I know it is a big ask however I need help with the schematic and programming. Any help will be greatly appreciated.
MrAl
Joined Jun 17, 2014
13,785
Hello there,
Are you sure that is the right schematic for a regular AC motor? It looks like it might be made for a special kind of motor.
Normally you would use either a half bridge and split supply (or split capacitors) or a full bridge which would provide excellent support for almost any AC load you can think of.
Also, your drill press may have a motor with brushes as many motors for stuff like that have. If it does, you can get away with a triac controller similar to a light dimmer. The VFD is needed mostly for AC only type motors.
Microcontrollers can take the place of a lot of logic.
LesJones
Joined Jan 8, 2017
4,538
Single phase induction motors do not run well away from their design frequency. You would be better off replacing the motor with a three phase motor and three phase VFD. It would probably cost more to buy the parts for a VFD than buying one ready made. (Plus the fact that you would probably destroy a lots of power switching devices in the proccess of getting it working.)
Les.
MaxHeadRoom
Joined Jul 18, 2013
30,791
I agree, I think you are wasting your time trying to provide VF to a 1ph induction motor, they tend to drop out of run at low rpm and under load.
Either a 3ph/VFD combo as suggested or a T.M. DC motor might be the better choice.
Max.
