arduino program for infrared not working
denison
Joined Oct 13, 2018
334
Here is the program which I copied exactly;
#include <IRremote.h>
int RECV_PIN = 11; // define input pin on Arduino
IRrecv irrecv(RECV_PIN);
decode_results results; // decode_results class is defined in IRremote.h
void setup() {
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
void loop() {
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
delay (100); // small delay to prevent reading errors
serial monitor gives this message;
'The function decode(&results)) is deprecated and may not work as expected! Just use decode() - without any parameter.' Get this message over and over on serial monitor. The program uploads ok to the nano board.
And this solution also does not work. Anybody suggest what is wrong with the coding.
Can never find the new post button on the Arduino website as I have now told them.
ericgibbs
Joined Jan 29, 2010
21,567
hi den,
Using a Nano , I get the same result with if (irrecv.decode(&results)) { , changing to () allows Compiling.
Where did you get the code.
BTW: I had to download the latest version of IRremote.h for the test.
E
