Arduino pro mini code burning
Danish45
Joined Jan 20, 2017
5
I am selecting the arduino pro mini from my Board option in the IDE, I have removed the ATmega328 IC from my UNO and using the following connections to burn code in pro mini using UNO:
DTR -------- Reset
VCC ------- 5V
GND -------GND
RX -------RX
TX------------TX
Danish45
Joined Jan 20, 2017
5
I am getting the following error:.
- upload error: stk500_getsync() error.
which I clearly dont understand what I am doing wrong.
Ibu Momda
Joined Mar 15, 2017
I just bought an arduino pro mini 5V 16MHz from http://www.w11stop.com/arduino-pro-mini-5v-16mhz and now having trouble burning the code in it. The pro mini is all good but I am unable to burn the code using arduino uno. Please help me as I am new to the arduino world.
now let me give you some suggestions you need to check first whether to install the driver of that ardino in your pc .you can found the driver with the kit that you bought in a cd form or you can download it.then start to install the ardino programming tool then use the guide to burn your code .
hope this will help you.
