Hi Folks, I'm trying to use a sketch (not my work) to control a high speed flash however when I try to validate it I get the error message: 'reading' was not declared in this scope. A certain amount of code is commented out as the sketch is a dual purpose solution for either controlling as laser trigger or a piezo vibration trigger. here is the complete sketch...There is also a screen shot of the error as shown. Thanks for reading, Cheers, Eugene.
C++:
/* This program is used as a laser trigger and/or sound trigger for high-speed photography<br> ---> Made by Sander Vanhee <--
push button to activate program
Activate laser or sound trigger
delay
open camera shutter (manual for now)
drop an object
laser barrier or piezo sensor gets triggered
laser off
wait the delay set by potentiometer
trigger flash
delay
close camera shutter
delay
int laserPin = 12; // red wire from laser
int potPin = 0; // potentiometer to read delay
int optoPin = 8; // towards the optocoupler
int buttonApin = 2; // pushbutton
int photocellPin = A1; // the cell and 10K pulldown are connected to A1
int photocellReading; // the analog reading from the sensor divider
int PiezoPin = A2; // the Piezo is connected to a2
int PiezoReading; // the analog reading from the sensor divider
void setup(){
// We'll send debugging information via the Serial monitor
Serial.begin(9600);
//#define photocellPin 1
pinMode(laserPin, OUTPUT);
pinMode(buttonApin, INPUT);
pinMode(photocellPin, INPUT_PULLUP);
pinMode(PiezoPin, INPUT);
pinMode(optoPin, OUTPUT);
pinMode(potPin, INPUT_PULLUP);
void loop() {
// check if button is pressed, only continue when pressed.
Serial.println("Waiting for buttonpress...");
if (digitalRead(buttonApin) == HIGH) { // start program if button is pressed
//start if(buttonpressed) loop
Serial.println("Button pressed");
// Read value of potentiometer
int reading = analogRead(potPin);
Serial.println("reading potentiometer");
Serial.println(reading);
reading = map(reading, 0, 1023, 1, 500); // scale it to use it with the drops (delay between 1 and 500)
delay(50);
/* We'll put the laser parts in comments to isolate them from the Piezo code
// Activate laser
digitalWrite(laserPin, HIGH);
Serial.println("Laser Activated");
delay(1000); // delay before open shutter
Serial.println("Drop object");
// read the value of the photocellPin
int photocellReading = digitalRead(photocellPin); //read value photocell and print it
Serial.println(photocellReading);
//Check if laser is broken
while (digitalRead(photocellPin)==HIGH){
Serial.println("Laser uninterrupted");
// as long as the laser is not broken, this "while" statement will loop.
// when the laser is broken, the program will continue.
// laser off
// turn laser off to not show up in the picture
// digitalWrite(laserPin, LOW);
// what follows is the piezo code
PiezoReading = analogRead(PiezoPin);
Serial.print("Analog reading = ");
Serial.println(PiezoReading); // the raw analog readingwhile (analogRead(PiezoPin)<1){
Serial.println("no sound detected");
int PiezoReading = analogRead(PiezoPin); //read value photocell
// Wait the amount indicated by the value of potentiometer
// give the waves time to rise back to the surface
delay(reading);
//trigger flash - send signal from pin 8
digitalWrite(8, HIGH);
Serial.println("FLASH fired");
delay(1000);
digitalWrite(8, LOW);
//wait for flash light to die down
delay(200);
//close camera shutter
Serial.println("END");
// END OF (buttonpressed) while loop
void setup() {
// put your setup code here, to run once:
void loop() {
// put your main code here, to run repeatedly:
