Arduino MEGA "AREF" LED Question
bea5017
Joined Sep 3, 2011
4
Guys,
I am looking for a little expert analysis of my frustrating situation.
I am monitoring the state of 4 separate IR photo diode sensors, through a single 4 channel op amp then ADC with an Inverting Schmitt trigger to be read by the arduino MEGA on pins 13,12,11,10. All seems well except.. that when one specific sensor (#3 sensor to be exact) is tripped, the "AREF" LED lights up on the MEGA. the other sensors work, but do not Light up the "AREF" LED as #3 does.
My question is why would the "AREF" LED light up with one, but not the other sensors are tripped, when all 4 sensors are wired up the exact same way?
Should this concern me that #3 sensor is not wired correctly?
What causes the "AREF" LED to light up in the first place?
I am worried that the MEGA is damaged in some way possibly....
Thought/Suggestions?
-Ben
bea5017
Joined Sep 3, 2011
4
After taking closer look, it is not "AREF" LED, but is the "L" LED as shown
Sorry for the confusion
Question still stands why only one of my sensors turns this LED on. Why does it turn on in the first place?
dl324
Joined Mar 30, 2015
18,460
Welcome to AAC!
Post a schematic so we can see what you're talking about.
What is the "AREF" LED for those of us who aren't familiar with MEGA.
bea5017
Joined Sep 3, 2011
4
Sorry for no schematic, I am at work but will update later.
After reading about the "L" LED (no wonder i was having trouble finding anything on AREF LED....) apparently it is attached to PIN 13
However #3 sensor is attached to pin #11 not pin #13 so I still do not understand why it turns L LED red when tripped.
I will have to double check when i get home that i have inputs going to the correct pins.
Only thing that makes sense is Having inputs wires in on wrong pins somehow and #3 sensor is actually on PIN 13... (lets hope its something that silly).
-Ben
bea5017
Joined Sep 3, 2011
4
Duly noted, Thank you for your patience with me.
I have tons of other questions for this Project. I may need to start a project thread, as i do not believe this is the right sub forum for them.
