Hi!
I have been working on this IR heat rate monitoring project I found on internet. It is simple setup...An ir emitter and a detector pair is used as a sensor...which is touched to your skin...it shines light up your skin and then reflected light is dected by the detector..this signal is then fed into an lm386 which amplifies the signal which is fed into an analog pin of an arduino. My Arduino has the following code running on it....
this is not my code...I found this on internet!!
This code flashes 10 leds with respect to your heart beat and also sends data through serial to the pc which is than read by a processing app which visualizes the waveform. It is cool, But I don't want the wave form. I want to calculate the "beats per minute". How can i do that? I don't want to use a pc instead i am planing to use a 16x2 lcd to display the calculated BPM. I have some experience with the arduino LCD library. But as i am new to programing I can't figure out how to calculate the BPM. I would be really helpful If anyone could help me modify this code to calculate the "BPM". I have to put this project on display tomorrow...so quick response will be really helpful !!
Rich (BB code):
int heart_high, heart_low;
int data[200], i, mapped;
void setup(){
for(i=2; i<12; i++)//LEDs
pinMode(i, OUTPUT);
Serial.begin(115200);//for the processing sketch
}//setup
void loop(){
heart_high=0;//reset the high before we look for it, everything is higher than 0
heart_low = 1023;//reset the low before we look for it, everything is lower than 1023
for(i=200; i>0; i--){ //search for the low and high out of the last 200 samples
data = data[i-1]; // move everything back one, this will leave data[0] empty, but we put the next read there after this
if(data>heart_high) //check to see if we have something higher than the current high
heart_high=data; //if it is higher, write the new value in
if(data<heart_low) //same idea as the high check
heart_low=data;
}//for loop
data[0] = analogRead(0); //now write the next analog value to data[0]
mapped = map(data[0], 0, 1023, 0, 600);
Serial.println(mapped); //send over the current value to the processing sketch, but scale it to match the screen height
delay(5); //delay in here is important, we need enough samples to catch an entire waveform, so at least 1 sec of samples should be tored in data[0],
//so 5ms x 200 = 1000, we're good
//This code is where we control the LEDs
if((heart_high-heart_low)>150){ //first, don't even go in here unless the span of the high and low is greater than 150. This is important, so the LEDs don't go crazy
//if you're flat lined
//I'll explain how one of these works
//There is an 'if' check for each of the LEDs
//Basically, how this works is we want the LEDs turn represent the entire span of a heart beat, which is why we get the lowest and highest value
//this gives us the span, which can be used to take a percentage of, and that's exactly how all these statements work
if(data[0] > (heart_high-.95*(heart_high-heart_low))) //this is true if the read is greater than 95% of the span
digitalWrite(2, HIGH);
else
digitalWrite(2,LOW);
if(data[0] > (heart_high-.9*(heart_high-heart_low))) // greater than 90% of the span and so on
digitalWrite(3, HIGH);
else
digitalWrite(3,LOW);
if(data[0] > (heart_high-.8*(heart_high-heart_low)))
digitalWrite(4, HIGH);
else
digitalWrite(4,LOW);
if(data[0] > (heart_high-.7*(heart_high-heart_low)))
digitalWrite(5, HIGH);
else
digitalWrite(5,LOW);
if(data[0] > (heart_high-.6*(heart_high-heart_low)))
digitalWrite(6, HIGH);
else
digitalWrite(6,LOW);
if(data[0] > (heart_high-.5*(heart_high-heart_low)))
digitalWrite(7, HIGH);
else
digitalWrite(7,LOW);
if(data[0] > (heart_high-.4*(heart_high-heart_low)))
digitalWrite(8, HIGH);
else
digitalWrite(8,LOW);
if(data[0] > (heart_high-.3*(heart_high-heart_low)))
digitalWrite(9, HIGH);
else
digitalWrite(9,LOW);
if(data[0] > (heart_high-.2*(heart_high-heart_low)))
digitalWrite(10, HIGH);
else
digitalWrite(10,LOW);
if(data[0] > (heart_high-.1*(heart_high-heart_low)))
digitalWrite(11, HIGH);
else
digitalWrite(11,LOW);
}//span check
else
for(i=2; i<12; i++)//turn all the LEDs off if we're flatlined
digitalWrite(i,LOW);
}//loop
