There are three things I'd like to suggest.Originally posted by damochi@Mar 8 2006, 05:40 AM
i have attached the circuit diagram please take a look and tell me if on the right track
[post=14769]Quoted post[/post]
1) Check the datasheet carefully to see if pin 4(Vref -) can be left open. It might need to be connected to something.
2) Pin 8 is a second Vss pin and it should be connected to GND
3) It is generally a good idea to place a capacitor, with a value between .1 uF and 1 uF across pins 19 and 20. This is called a decoupling capacitor and it has two purposes. It is a path to GND for high frequency AC noise from the power supply and it provides some energy storage to prevent Vdd drop when the device is switching. You're not doing much output switching so this may not be critcal for a breadboard.
