Arbitrary digital signal with different pulse widths
AnalogKid
Joined Aug 1, 2013
12,284
Maybe use a CD40174B HEX-D to reduce the DFF chip count in post #7?
Nope.
While the 4017 can appear to function as a specialized shift register, and is in fact based on one internally, its outputs are mutually exclusive. The consequence of this is that the XNOR gate, which is a key element of most LFSR circuits, will not function correctly.
With the 4017, only one output can be high at any time, for a total of 10 possible codes in a perfectly predictable sequence. With a true shift register, all binary output combinations (64 in the case of post #7) are possible *and required* for correct operation.
ak
38,871
Any reason the 6-bit shifter couldn't be replaced by a single-chip 8-bit SIPO?
None I can think of.
For example, below is the LTspice simulation of the generator using a 74HC164 8-bit parallel out shift-register.
Again U8 and U9 act as a digital one-shot so the output is never low for more than one clock cycle.
eetech00
Joined Jun 8, 2013
4,734
Nope.
ak
what 4017?
