I am searching for a high-value application for our new wire/trace/electrode material: ultraconductive copper (UCC). This material has 120% of the conductivity of pure copper at room temperature ("120%IACS"). After 13 years of R&D we have this material working in the lab. To get a start-up company funded we need a high value application to address, as the material will likely be significantly more expensive than pure copper in first, pilot quantities. Such applications are usually characterized by a "must have" need for higher material performance (not just "nice to have"). To get you started, here is one such application we have confirmed: the contact pads on Silicon Carbide IGBTs. These devices are used in power switching, for instance in the inverters of electric vehicles. Current into the device heats-up the electrodes and the Silicon Carbide itself heats up in operation. Heat from both sources must pass out through the electrodes themselves to reach the heat sinks. This type of IGBT is limited by thermal runaway because of these effects. UCC, with its higher electrical and thermal conductivity can increase the performance of these IGBTs. Your other ideas for applications that would benefit from UCC?
