so, i'm stuck, i wanted to design an led driver circuit schematic that has 220VAC mains and uses supercapacitors to store power incase of an emergency power shutdown/ load-shedding but will stay lit when the power is on and when the power is off and at the same time, i could easily turn off the lamp from the switch.
any suggestions on the kind of ICs i should use?
any help will be appreciated, thanks alot.
