C Thread Starter Curlywurly Joined Mar 16, 2019 8 Mar 22, 2019 #3 Yes, im struggling with understanding this homework question
dl324 Joined Mar 30, 2015 18,501 Mar 22, 2019 #4 Thankfully I responded before someone helped you cheat. What theories have you studied?
C Thread Starter Curlywurly Joined Mar 16, 2019 8 Mar 22, 2019 #5 We are currently doing kirchoffs laws and superposition
dl324 Joined Mar 30, 2015 18,501 Mar 22, 2019 #6 What do you need to use with multiple independent voltage sources?
C Thread Starter Curlywurly Joined Mar 16, 2019 8 Mar 22, 2019 #7 Superposition. I found the voltage across the 4k resistor when I removed the 4v source and then did the opposite when I removed the 12v source. This gave me an answer of 8.8 volts and I am not sure where I have gone wrong
C Thread Starter Curlywurly Joined Mar 16, 2019 8 Mar 22, 2019 #9 Here it is Attachments 20190322_180628.jpg 145.6 KB Views: 12
dl324 Joined Mar 30, 2015 18,501 Mar 22, 2019 #10 Might be simpler if you stop after calculating currents. Do the arithmetic on the currents to get the voltages.
C Thread Starter Curlywurly Joined Mar 16, 2019 8 Mar 22, 2019 #11 So 2.4 - 08 = 1.6mA... but then what?
dl324 Joined Mar 30, 2015 18,501 Mar 22, 2019 #12 Curlywurly said: So 2.4 - 08 = 1.6mA... but then what? Click to expand... Same thing you did before, but be less sloppy with magnitudes and units. Last edited: Mar 22, 2019
