Anyone know how to debug code in STM32Cube IDE
John99407
Joined Jul 12, 2019
77
I am finding it very difficult to debug code in STM32Cube IDE. I have gone through the user manual of STM32Cube IDE but I don't understand How do I debug code on STM32Cube IDE. Anyone know how to debug code in STM32Cube IDE
C:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * <h2><center>&copy; Copyright (c) 2021 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
       HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_12);
       HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_13);
       HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_14);
       HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_15);
        HAL_Delay(500);
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_RESET);
  /*Configure GPIO pins : PD12 PD13 PD14 PD15 */
  GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
35,181
Here I am using STM32CubeIDE 1.5.0 while debugging code for STM32F4 Discovery board.
I position the cursor in the left margin (just left of the line number) opposite the line of code that I wish to place a breakpoint.
I right-click on the mouse and select Toggle Breakpoint.
Then I click on the Debug icon in the main menu bar.
Click on Resume (F8) and the program will run until the breakpoint is encountered.
If you remove the breakpoint, you can run the program and then pause it by clicking on Suspend.
In this example, you can observe that the program was suspended in the delay( ) function and the value of d is 98.
John99407
Joined Jul 12, 2019
77
@MrChips I now understand how to check variable value. How do you know the status of Pin changes.
In the given code, status of Pin 14 changes after every 250ms How can it be detected when status change in debugging window
C:
  * @file           : main.c
  * @attention
#include "main.h"
void delay (long int d)
  while (d) --d;
  * @retval int
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  /* Infinite loop */
  while (1)
    /* USER CODE END WHILE */
/*        delay(1000); */
        HAL_Delay(250);
    /* USER CODE BEGIN 3 */
  * @retval None
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
    Error_Handler();
  * @param None
  * @retval None
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_14, GPIO_PIN_RESET);
  /*Configure GPIO pin : PD14 */
  GPIO_InitStruct.Pin = GPIO_PIN_14;
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
35,181
As far as I know, debug mode is useful for interrogating the machine in static mode, that is, when the program is paused after reaching a breakpoint.
If you want to observe the state of an I/O pin dynamically, use an oscilloscope or an LED.
John99407
Joined Jul 12, 2019
77
Usually registers can be viewed under SFRs tab
I looked under general register. I don't see SFR tab. I have attached screenshot
I don't have oscilloscope. I am asking for static mode When program stop at line 105 (breakpoint.) I want to check state of Pin14
John99407
Joined Jul 12, 2019
77
You write to pin in GPIOD, so look at GPIOD register. Better way to debug a output pin is attach a LED to this pin as @MrChips pointed.
It also can be checked by connecting LED. Main purpose is to check the status of pin weather that pin is input pin or pin is output pin.
How to observe status of Pin14 in GPIO register
John99407
Joined Jul 12, 2019
77
See OutputDataRegister (ODR) bit that corresponds to Pin14
Got it,
I am checking status of push button under GPIOA -> IDR pin R0. Status of push button doesn't change when button press is detected
C:
  * @file           : main.c
  * @attention
#include "main.h"
  * @retval int
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  /* Infinite loop */
  while (1)
       if ( HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_0) == 1)
            HAL_Delay(250);
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
  __HAL_RCC_GPIOA_CLK_ENABLE();
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12, GPIO_PIN_RESET);
  /*Configure GPIO pin : PA0 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /*Configure GPIO pin : PD12 */
  GPIO_InitStruct.Pin = GPIO_PIN_12;
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
BobaMosfet
Joined Jul 1, 2009
2,211
@John99407 Normally, you should read the documentation with your IDE, and the datasheet for your MCU so you understand both sufficiently to be able to use them. Then experiment and learn. If you are uncertain what an SFR is- you need to read your MCU datasheet and figure that out. Not being mean, just saying. All the rest of us did it this way.
And the tool in the IDE for debugging- it's called a Debugger. Learning how to debug without it will teach you more than with it, although it is a nice convenience.
John99407
Joined Jul 12, 2019
77
Have you enabled pull-up or pull-down resistors? If switch is between pin and ground, enable pull-up.
I have enabled pull-up resister. When i run program LED start blinking without pressing user button while I want to blink LED when i press the button first time.
C:
  * @file           : main.c
  * @attention
#include "main.h"
  * @retval int
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  /* Infinite loop */
  while (1)
            HAL_Delay(250);
  * @retval None
    Error_Handler();
    Error_Handler();
  * @param None
  * @retval None
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
35,181
If the switch is a contact to ground, pressing the switch would input a logic LOW.
Try this instead:
if ( HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_0) == 0)
John99407
Joined Jul 12, 2019
77
Try this instead:
I am using user button on the board to blink LED. should switch be connected to board ground. I tried The change you mentioned. when I am pressing the button, LED is off
