I got 1 last year and I didn't realize until today that people were upgrading to the 1mV version with firmware.
I have EasyPower and N.I. files installed. My machine is hardware V3.0, software/firmware: 1.01.01.02.05
I tried this (from https://www.eevblog.com/forum/testgear/siglent-ads-firmware-file-format/msg1830584/#msg1830584) with the attached file. And it didn't work, trying normal mode FW update it says "This file is not upgrade file!"
IDK anything about making memory dumps and decrypting 3DES. Anyone upgrade 1 of these lately , anyone have any working have firmware or idea's ?1. Run the SCPI command in the X-E to enable the 1mV step:
FACTORY ON
2. Using EasyPower flash the required FW file from the attached ZIP. (ConvertFromX-E)
(3. If you want to rollback, flash the other file.)
The FWs are Siglent official versions with Prod_ID's swapped like janekivi suggested.
The HW version of the board where the test was done is 0.3.
