anybody know where i can get a replacement 9-pin circular connector?
kmccabe87
Joined Oct 7, 2017
where there are 2 pins, they are equally spaced..... the 4 pins in the middle of the connector has 1 of the pins offset a little bit, and the bottom 3 pins are equally spaced. the board is from a Ridgid SeeSnake MicroReel CA adapter cable... most of the connectors i was able to find that had 9 pins had a different pattern. instead of the middle 4 pins with one of them being offset, they had the bottom 3 pins with one of them offset(https://www.digikey.com/products/en?mpart=MD-90&v=102). there was one that i found that had the exact pattern but it was a right angle(http://www.king-cart.com/store/phoenixent/dinmini9792d.jpg)
philba
Joined Aug 17, 2017
959
Your second link doesn't give much to go on but if you can find the manufacturer of the right angle part, you could go to their website and find the part number of the vertical version. then search on that. Then look at their distributors and hopefully one of them will carry it.
