Anybody know what this is?
dl324
Joined Mar 30, 2015
18,362
Insufficient information.
You don't need to use a .docx file; many won't open them (even though .docx aren't supposed to contain macros).
Danko
Joined Nov 22, 2017
2,173
Typical Application for MIC5252: 150mA High PSRR, Low Noise Cap CMOS LDO. The MIC5252 is an efficient, precise CMOS voltage regulator optimized for ultra-low-noise applications. It offers 1% initial accuracy, extremely low dropout voltage (135mV at 150mA) and low ground current (typically 90μA). The MIC5252 provides a very low noise output, ideal for RF applications where a clean voltage source is required. The MIC5252 has a high PSRR even at low supply voltages, critical for battery-powered electronics. A noise bypass pin is also available for further reduction of output noise.
MisterBill2
Joined Jan 23, 2018
27,664
OK, now I see! But all should know that single surface mount transistors are offered in every possible connection arrangement, all with the same part number and only a letter following to describe which is which. Also opamps. That confused me fro several minutes while checking a PCB design against the circuit, a while back ST semiconductors was the guilty party at the time.
