I'm working in a project which involves mains. It's a board fixed in a metal chassis, where this chassis serves as heat sink for a power mosfet, but the MOSFET's drain is isolated from it. What should I connect to the chassis? Main neutral/ground? Digital ground? I've seen some boards that uses a low resistor path from digital ground to chassis. I have also seen other boards where the main ground is connected to another system ground through a RC network to avoid ground loops (I think). Also, I've seen situations where the main ground is not simply connected to anything. What are your opinions?
