Well, I built my garage alarm on a vero board using a 556 as a two purpose delay. The first is a man door delay timer so you can disarm the circuit before it goes into alarm. I intended to use the other half as a long time delay to reset or disable the entire circuit after it has sounded for some time.
Stupid me.... I wanted the second half to stay off until the alarm sounds, then go into astable mode to start a 4017 decade counter and finally trip a transistor latch relay circuit to remove power to the rest of the circuit, shutting off the alarm. Whoops, is there any way to block the astable mode NOT using the VCC pin on the 556? (I still need the other half powered for the door circuit...)
DUH...... didn't see that coming....
Thanks in advance!
Thanks in advance!
