AND, NAND n OR, NOR gates
kubeek
Joined Sep 20, 2005
5,796
How about the one that fits the circuit the best?
You can build any circuit from either xors, nors or nands, or from AND and NOT gates, or from OR and NOT gates.
Nands are sometimes used as basic building blocks, since they only use 4 transistors in cmos circuit. Nor uses 4 transistors as well.
Without knowing what you´re building it is hard to tell. You could be talking about ASIC design or building from discrete chips..
ScottWang
Joined Aug 23, 2012
7,504
You should post what you want to do?
What's the input and what's the output?
I don't think the members at here are the mind readers.
JMW
Joined Nov 21, 2011
138
Welcome to the forum. In the olden days "N" type gates were preferred. The reason being is they would "sink" or pull down a voltage. If a short occurred no damage. Or's and And's "sourced" a voltage. If you shorted the output you toasted the IC.
38,624
That's not true of any modern IC logic gates, of course. ;)
38,624
If you want minimum delay then you need to look at the data sheets for a particular logic family. Generally AND and OR gates are slower than NAND and NOR gates because they have a stage added to invert the signal from the basic input NAND or NOR function.
33,044
Among AND and NAND , OR and NOR gates, practically which would be preferable
As others have indicated, NAND and NOR gates, as a rule, are faster and require less silicon area because they only use 4 transistors instead of the 6 required for an AND or OR (talking CMOS here). Between a NAND and a NOR, the NAND has an advantage because the NFETs are in series and the PFETs are in parallel. NFETs, for the same size, have better drive strength so you can use, roughly, the same size (i.e., minimum geometry) transistors and get a balanced circuit. With a NOR, you generally need to increase the size of the PFETs considerably to achieve this.
33,044
Yep. Somewhat counterintuitive that they aren't. But when you flip inputs and outputs on and XOR you either get an XOR or an XNOR back.
Another gate that is functionally complete is a 2:1 MUX.
