Hi All.
I have a project that requires the use of 8 inductive prox sensors that need to feed digital input via USB to a laptop.
As you've most likely already worked out, I'm not clued up in this field and need help.
Essentially, this is for digitizing a bell tower in the UK where we need to be able to swing the bells in the normal fashion to be able to teach technique but have the clappers silenced so as not to annoy the townfolk.
Mechanically this is very easy, the bells will each have a prox sensor reading bottom dead center, this then feeds in to a piece of software called Abell, I just need help with the wiring side of things.
Hopefully someone will be able to guide me.
Thanks Steve
Thanks Steve
