Analog Multimeter
tuzlaaelectronic
Joined Jul 22, 2017
7
Hello
I need help with my analog multimeter. I'm using it for testing capacitors. Issue is that needle wont move when I want to measure resistance or something else.
I take a look inside, everything seems ok.
Alec_t
Joined Sep 17, 2013
15,156
If the needle is able to move a bit when you rotate/shake the meter gently then the movement is not jammed. In that case there is an open circuit somewhere.
If you were discharging capacitors into the meter when on a low current range, the meter movement coil could be blown, as discharge currents can be high.
ian field
Joined Oct 27, 2012
6,536
Hello
poking the resistance range on to anything over about 22uF should kick the pointer a bit as the test current charges the capacitor, a highly sensitive taut band suspension meter might show some sign of life with smaller capacitance.
Some DMMs have a few capacitance ranges. With electrolytics you might want to test ESR - that's a whole 'nother instrument.
