Analog input circuit 0..10V and 4-20ma
dr.luk.bgd
Joined Jul 6, 2023
7
Hi to all,
I am looking for an example of circuit for PLC analog input.
One input shall have 3 terminals : Ui, Ai and Com. Ui - voltage input (0..10V) , Ai - current input (4-20mA) and Com- common. Depends of Analog input electrical connection signal will be conditioned over 12 bit A/D converter.
If someone have idea or solutions please share it for future discussion.
Thanks.
28,411
Does the TS want to know how to utilize the inputs? Or how to produce them? Analog Voltage inputs on a PLCoften share one common among multiple inputs, with the common being the more negative side.
Current loop inputs (4-20 mA) may share a common connection to a loop source for several input channels, or they may even be assignable more flexibly. That is a read the book sort of challenge.
MaxHeadRoom
Joined Jul 18, 2013
30,842
So is this for use with a commercial PLC or self designed version?
If commercial recognized make, major companies have these modules available.
Or, is this a self designed PLC that you require to design the modules for?
Is this for a special case unique/project?
