KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
I would like to inject a few comments here:
#1
Car sensors are ratiometric to the supply voltage of usually 5V. The reference is whatever Vcc is divided by 2. The sensors cannot reach 0 or 5V
#2
I personally had this MAP sensor experience.
Replaced a bad MAP sensor in a car. Two days later a family member took the car out. Car would not keep running at idle without foot on gas. ECM would not recognize a bad MAP sensor. I was able to DISCONNECT the MAP sensor and get into limp mode. I replaced the sensor in the parking lot of the automobile supplier.
Check out AD22057: https://www.analog.com/media/en/technical-documentation/data-sheets/AD22057.pdf (Sensor to ½ supply)
For your summing amp to work, V1 and V2 have to be low impedance sources.
#1
#2
