Hi All
I have to design (and build) a UPS with 3kW power output, and I have some constraints that don't allow me to simply buy one.
1. Cost. UPS-es with such a power output are usually pretty expensive and I can't afford buying one (plus I'm itching to build it myself
2. Square wave. The UPS will have to drive some induction motors and I believe they don't handle square wave very well, because of spikes and harmonics that occur if an induction motor is ran on square wave power.
I actually tried to run a small induction motor on a square wave UPS. It had a fraction of it's nominal power and soon I felt a smell of burned insulation, It kept running though, so I can't be sure if that was the cause.
So I have to design my inverter to output real sine wave or at least not very rough step-sine wave.
3. Big transformer. As you might imagine, a 3kW, 50Hz transformer would be quite big and heavy. I'd like the device to be as small as possible and light too.
A particular design is "rolling" in my mind, so I thought I could use a third-party opinion before I throw the effort to build it...
This is how it goes:
1. The 12 volts form the battery are fed into a powerful DC to DC converter, which outputs 300V DC with maximum power output of > 3kW.
2. Those 300 volts, power a class D amplifier, which outputs 220V, 50Hz, ~3kW.
3. In order for the amplifier to to output a 50Hz sine wave voltage, it uses a simple sine wave generator for the input signal.
That's it. Easy to explain.
My question is, how feasible do you think that design is?
Here are my pros and cons.
cons:
1. It's complex - lots of points of failure.
2. Possible reliability issues.
3.Possible reduced efficiency; even though switch mode DC to DC converters and class D amplifiers are very efficient, chaining two in a row might have it's consequences efficiency wise... What you you think?
4. A class D amplifiers are designed to drive speakers which have a constant impedance. I this case the load could change rapidly, and there could be spikes and other fluctuations with possible adverse effects. Although I'm not terribly concerned sine class D amplifiers have and LC filter at the output that would have some protective effect aside of it's main function.
pros:
1. Relatively low cost. That depends of course, but I think it'll be cheaper than a huge near-solid chunk of metal.
2. low mass and size. The DC to DC converter is going to run at 60kHz or 100kHz. So I could use a small ferrite transformer. (toroidal maybe) Certainly it'll be much smaller than a 50Hz transformer... And that of course meets one of my main requirements.
3. (Near)real sine wave. The amplifier doesn't have to be audio-equipment quality, it could be a crude one. As far as I know usually they run at 400kHz, mine could run at as low as 30kHz or even lower. And that covers the last of my requirements.
So that's it. What do you think of that design?
Does it exist by the way? I haven't seen such a design. (I hope I don't show myself as too ignorant
Thanks in advance
cons:
pros:
Thanks in advance
