Any capacitor will block dc but why use the 220nF and 100k ?The 220nF cap will block DC and low frequency AC, but allow most audio frequencies to pass.
The 100k resistor is a potentiometer, it is a light load on the output of the mic, and allows controlling the level of input (as a volume control) to the amp.
I understand that the fc = 1/2*pi*RC where fc = cut off frequency
From this I get 1/2*pi*220nF *100k = 7.23431554 hz
unless I calculated something wrong. Would this mean that it blocks all frequencies lower then 7.23 ...etc hz
If that is the reason why not get the RC combo close to 20hz that would filter more noise out I would think?
Unless I am missing something?
using the above formulaFor example, the 470uf output capacitor into an 8 ohm speaker will produce a response that is -3dB (0.707V) at 42.5Hz.
I get fc = 1/2*pi*RC = 1/2*pi*470uf *8ohm = 42.328442 ...etc hz
so this would mean it cuts off any ac that is under this frequency.
If I am correct in all my calculations then these both are a form of high pass filters where everything over the cut off fc frequency is pass thru and everything under it is blocked out.
question -3dB (0.707V) how did you come up with this I can only calculate the fc why/where is the -3dB (0.707V) coming from?
Or the fc - 3dB in your formula???
Also 0.047uf and 10ohms is this just another filter to block stuff if
I calculate 1/2*pi*0.047uf * 10ohm = 338627.5384933943 hz =
approx 338.6 khz so it would block any frequency below this and let all frequencies higher then this go thru. But the voice is only in the range of 20hz - 20khz at most so I don't know how useful this R C is ?
Maybe it is the combination that does something or maybe I am missing some reason??? Either way I will look into the Boucherot cell. (my their lies the reason)
thanks
