KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
The NI ELVIS http://www.ni.com/pdf/manuals/372590b.pdf seems pretty good for 5.5 digits in the DMM mode of that's what your using.
It should be for what NI charge for them!The NI ELVIS http://www.ni.com/pdf/manuals/372590b.pdf seems pretty good for 5.5 digits in the DMM mode of that's what your using.
It measures 255k ohms between pins 1 and 6, also between 5 and 8I could'nt find anything wrong with your set up.
Can you measure the resistance between pin 1 and pin 6 also 8 and 5 should measure 350k
if it measures 145k then it is an INA118 the laser trim operator mixed up part of a the batch.
then Rg = 50 ohms G=500 and you have an INA118
