Amplifier not amplifying
geir553
Joined May 22, 2017
12
Hi
I'm trying to fix an amplifier that is built in to a speaker. When I play music I can hear it but the volume is very low. Any tips on what to check here?
I’ve found two u1620g on the circuit board. Does it sound like these might be blown?
AlbertHall
Joined Jun 4, 2014
12,640
Without more information it could be almost anything.
Give us a make and model - it may be possible to find some useful information on www.
Also some good photos of the board from different angles might help.
Do you have a multimeter?
geir553
Joined May 22, 2017
12
I have multimeter and oscilloscope. The speakers are called Tapco Thump 15a. I see there is schematic online. I dont have the board in front of me right now, but I can snap some pic later if needed
35,060
First step would be to open the unit and do a thorough visual inspection.
Look and smell for any damaged or stressed components and pcb. Look for heat stress on resistors, discoloration on pcb, bulging or leaking capacitors.
AlbertHall
Joined Jun 4, 2014
12,640
It uses a switch mode supply which means a lot of exposed live mains inside. If you are not used to working on such equipment it is very dangerous to attempt repairs. Further, if the fault is in the power supply, they are very difficult to repair even with experience of such work and to try to do it by 'remote control' from here is unlikely to say the least.
If you want to proceed and if the fault is not in the power supply, as MrChips says the first step is a visual inspection.
I found the schematic but no board layout so good pictures will help a lot.
35,060
Sometimes knowledge of the history of the unit can provide some clues of failure mode.
Are you the original owner or did you acquire this recently?
Did you acquire the unit as is, i.e. it was not working when you got it?
Same question, have you seen/heard the unit working? Did the unit fail on you while using it? If so, what were the conditions before and after failure?
This is not an interrogation but sometimes it might lead to some useful clues.
35,060
The next step would be to identify all the power supply voltages from the schematic and then take voltage measurements with a voltmeter.
+3.3V
+5V
+15V
-15V
+28V
-28V
We will side step +300V for now.
geir553
Joined May 22, 2017
12
No problem I would not ask if I did not want you to ask back :) The previous owner said it just stopped working while using it. Don't know any more than that I'm afraid. I'm off to bed, but I'll check voltages to tomorrow. Thanks for your help so fare :)
geir553
Joined May 22, 2017
12
Checked all the voltages. Everything checks out so I guess I can assume the power supply is ok and the amplifier board is the problem?
35,060
Ok, now the fun begins. You said you have an oscilloscope. That's great. How competent are you at trouble shooting using an oscilloscope?
Here are possible suspects that we want to identify.
1. Preamp stage is faulty.
2. Main amp is faulty.
3. Something else is preventing audio output, for example, mute.
Your main amp is TDA8924TH Class-D power amp wired in mono mode.
What is the make and model of your scope?
Are you using a x10 attenuation probe?
For simple starters, use the oscilloscope to probe the signal on L203 and L204, on the side connected to the TDA8924 output pins.
Do this with no input source.
Here is the schematic for your amp.
Here is the TDA8924 example for reference purposes.
35,060
Back up.
With your voltmeter, measure the voltages at both ends of R200 and R201 or at L106, L107.
This is the power supply feed to the amp (top left on your amp schematic).
geir553
Joined May 22, 2017
12
Wow this is really helpfull :) R200 is +28 on both sides. R201 is -28 on both sides.
R204 is at 0V at both sides. Which leads me to belive the aplifier is off? But why?
(I messured R222 which is at 60 ohm.)
PS I'm not verry competent trouble shooting with a oscilloscope. And have not started that part yet since this seems to be the way to go.
35,060
That is very useful. Hopefully you're on the right track.
If R204 is at 0V then MODE is 0V and the main amp is off.
I see the circuit above the TDA8924 is TDA7294 which is also a 100W linear amp. What is that being used for? (side track)
(on track)
If pin-1 on conn 10 is at 0V then something is wrong with Q201 (unless if pin-1 needs to go negative for cutoff).
Can you unsolder Q201 or at least lift the drain lead off its solder pad?
geir553
Joined May 22, 2017
12
Sidetrack: Looks to me like TDA8924 is for LF and TDA7294 is for HF
Ontrack: Yes I can desolder, but are you sure? When PIN-1 is 0 that means the gate of Q201 is 0 and open. So left side of R204 sould be 0 as it is. Or am I wrong here?
35,060
Ok, I now see where MUTE is generated. There is an opto-coupler off the power supply board.
Yes, conn-10 pin-1 has to go negative for the amp to be ON.
So something is wrong at the opto-coupler circuitry.
Be careful around that part of the circuit. You're looking at 300V.
It would appear that the opto-coupler is bad.
Measure the voltage across the emitter diode of the coupler, pins 1 and 2.
Measure the voltage across the photo-transistor, pins 3 and 4.
