I am trying to build a small microphone amplifier for an electret microphone. I am using an LM358P duel op amp IC to amplify the signal. From my understanding of the design, the first op amp is used to boost the current in a voltage follower configuration. I then use a capacitor to off set a slight DC bias of 80mv. I use a pot as a voltage divider make my voltage in an ideal range for my ADC. I then use the second op amp to amplify the signal with another pot (Design 1). I didn't really see much of an amplification. If my understanding is right, with a 10k pot, I should be able to get from 0 - 10k ( or the op amp max) voltage amplification. However when I adjust the second pot, I see no change in amplification. I tried manually setting the amplification to 30x with a 47k and 1.5k resistor (i have it marked 300k and 10k in the diagram 2). The signal stayed the same, though the signal got a little noisier. Last thing I tried was to switch the order of the bias removal, just incase I needed the signal in the middle of the op amp range before passing it to the voltage follower (diagram 3). No Joy.
My gut says something is wrong with my op amp ic, but I'm not sure how to test it. Setting up a voltage follower on both op amps works fine, but neither seems to amplify.
