Hi Guys
Right then my latest weird and wacky circuit involves the control of a the mute function on an AN5279 Amplifier chip. The amplifier circuit itself is very simple requiring only a minimum of parts to get it running.
This project will run on 12VDC.
2 pins of the chip require 5V as a control voltage. The standby pin needs 5V +VE for the amplifier to be 'ON' A simple resistor potential divider will be used to attain this .
Now the mute pin responds to 2 states or inputs. +VE 5V will mute the output. 0V will un mute the output.
My intention is to use a 7555 timer circuit to control the speed at which this mute happens. I am not looking to turn the mute on and then off when I want this is a permanent cycle running at whatever speed I set the timer to run at.
Now the bit where I lose it is the actual joining of the 7555 output to the mute control. I believe I need a transistor driven by the 7555. The collector goes to +VE supply with 2 resistors in line to form the resistor potential divider for the 5V needed to control the mute.
So when the transistor is off the mute pin gets the +VE 5V so the chip is muted. When the transistor receives a signal from the 7555 it opens and the mute pin is taken to 0V or GND.
I attach a diagram of my intention. Have I got it right as far as the interface of the 7555 to the mute pin is concerned?
regards
Fenris
regards
Fenris
