Amplifier bias-point modulation
mhx_at_aac
Joined Jun 9, 2024
2
When toying with the equivalence between impulse response and transfer function I noticed someting I did not expect.
In the circuit below, V1 injects a 10ns wide square-pulse (Dirac impulse) into an AC-coupled 2-transistor amplifier.
On a time scale of 300us the response is as expected. An FFT over this interval shows a -3dB bandwidth of 30kHz
and a gain of 69dB, the same values that the SPICE .AC simulation comes up with.
Here the FFT of V(out)/V(in), aka the transfer function.
However, a 300us interval is too short to show frequencies below 3kHz, so I expanded the FFT window to 1s. The simulated time waveform now reveals an additional, superposed, exponential decay of the signal on node out.
This long tail completely drowns out the short-window results an produces the FFT shown below:
The response over a 1s window is completely different from the expected one (first picture above) and suggests a much wider bandwidth and a much higher (+50dB) gain.
What happens here is that we only see the transfer function related to the impulse response shown between 300us and 1s. The 10ns input spike temporarily upsets the DC biasing of the amplifier. Because of the big capacitors it takes almost a second before this second transient dies out.
My question: Would this effect influence the subjective sound quality of this amplifier, i.e., can people hear the effects of this bias modulation?
In practice there will not be any 10ns spikes on the source material, but there might be RF noise pickup on the input when it is not explicitly filtered. Intentional spikes (be it much wider) can be in the programme source and their effect might be proportionally larger.
ericgibbs
Joined Jan 29, 2010
21,572
hi mhx,
This is a version with the test parameters expressed in an alternate way.
The circuit is as your original circuit.
The pulse does take many 10's of uSecs to decay at the output, but I would consider as the change in the output is only mVolts, its effective would not be audible.
The large capacitors in the feedback loop I would say are the cause of the long delay.
E
mhx_at_aac
Joined Jun 9, 2024
2
Thanks.
With UIC off, the DC-voltage across C1 (and other components) is not ok (the dc voltage across R2 should be 0 in the working point).
If you want to see a higher output voltage, increase the amplitude of the input spike.
-marcel
