Amp Audio Probe Build - Not Sure Where To Locate The Potentiometer
martinsbm
Joined Feb 7, 2017
6
Please see the attached diagram…
I'm building an audio probe to track/trace a signal through a guitar amp board. Not sure whether it would be better to put a POT inline with the capacitor or the ground lead. Thoughts anyone?
martinsbm
Joined Feb 7, 2017
6
I see no reason for either.
Why do you think you need them?
The person who showed how to make them said that sometimes people replied that the 10nF capacitor left the AC signal a bit strong for some batt-op'd speakers. So, I thought putting a VR (POT) inline might allow some attenuation adjustment. Newbie. Based on a test in iCircuit.com's app, it appears that if inline with the capacitor, it would work. But, thought I check in with an expert first for a bit of advise. Thx.
martinsbm
Joined Feb 7, 2017
6
This from another EE…
Your circuit has the right stuff to work. If you touch a plate lead with your probe, there will be enough current passed by the capacitor's (initial contact) to pop the amplified speaker front end. For audio signal tracing, I would suggest about 500pF max for the cap, and a resistive coupling to your coax center conductor, out to the amp. At the amp, some diode's as limiters would be safe to protect the amplifiers front end.
Stephen Martin
Noting your recommendations, and may try to learn more about MOVs and using an NTC Thermistor as surge suppressors as well. I had thought that the feedback reports were concerning too strong a signal to the battery speaker amp, but now I think it's about a surge during capacitor charging.
