Amazing transmission of QRP
Willen
Joined Nov 13, 2015
339
I saw many QRP circuits, and most of the article are saying one watt QRP can transmit more than usual (like upto 45,000 miles). But I am not getting answer how the QRP is able to transmit such long distance? Transmitter seems pretty simple, then do they use complicated pretty high gain beam antenna? Or do they use super sensitive receivers? Are there clear examples?
DickCappels
Joined Aug 21, 2008
10,661
I think you mean 4,500 miles. Yes, antennas play a crucial role.
They often use CW (Morse code) and very narrow bandwidth to reduce noise at the receiver. The more sophisticated approaches involve keying the transmitter with a digitally generated pseudo random sequence and using a synchronous demodulator and low pass filter at the receiver to pull the signal out of the noise.
Willen
Joined Nov 13, 2015
339
Hi Dick,
I found a sentence in the internet (wikipedia) which is more than 45000 miles per watt maybe. This one:
The current record for a QRP connection is 1 µW for 2640 kilometers (1650 miles) on 10-meter band (28-29.7 MHz)." (https://en.wikipedia.org/wiki/QRP_operation)
Which is out of my imagination! And it's interesting that narrow bandwidth has less noise but confusing is that as I know professional FM has 100KHz bandwidth in its carrier and AM has almost 5KHz bandwidth (I even do not it is bandwidth or not) but FM is noise free than AM.
Thank you for the links bertus, I wish I can learn the fact from the links and ebook suggested here.
DickCappels
Joined Aug 21, 2008
10,661
45,000 miles per watt sounds credible. It is just that there are no two points on earth that are more than about 12,500 miles apart.
Some of those who listen for beacons use handwidths as narrow as a few Hz, which requires tremendous stability of the transmitter and receiver tuning.
Here is an article about how noise relates to bandwidth that you might find interesting.
http://www.highfrequencyelectronics...dth&catid=94:2014-06-june-articles&Itemid=189
12,289
You are trying to compare the performance of two things that are very different. Broadcast commercial AM and FM have very different bandwidths, but that has nothing (zero) to do with the noise performance of each modulation technique. FM is less susceptible to amplitude noise because of the limiter in the receiver, not because of the modulation bandwidth. And it still is susceptible to phase noise and multi-path distortion.
