AM Radios Discussion
Wendy
Joined Mar 24, 2008
23,807
Back when I was in college I majored in electronic communication which also included AM radio stations. So I have been reviewing what I used to know about AM radios starting with crystal receivers. Most of the tuning caps of that era were 10pf to 365 pf. The popular antenna of that era for handheld receivers what is a ferrite coil antenna. I'm trying to recover what the inductance range these antennas were in. The frequency range the tuner had to cover was 530 Khz to 1600 Khz. For the life of me I can't remember what the antennas were in inductance. Discuss?
Wendy
Joined Mar 24, 2008
23,807
Did that:
https://www.omnicalculator.com/physics/resonant-frequency-lc
C=10pf L = 250µH fo = 3.1831MHz
C=365pf L = 250µH fo =533.49KHz
I was trying to figure out the inductance of a ferrite antenna, just recreating an exercise I did in my 20's. I believe it was 250µH which seems to work.
I could do much better this time around 40+ years later (oops, did I say that out loud?). I didn't know about schottky diodes back then. It is a bit dismaying I can't do math like I used to.
BobTPH
Joined Jun 5, 2013
11,618
Yes, that checks out. I get 247uH.
At the low end, 40pF is required. But stray capacitance will likely be a good portion of that, hence the low of 10pF.
Wendy
Joined Mar 24, 2008
23,807
When I was a kid I would buy 100' of wire and attach it to a tree with a screen door spring to keep it tight. Got fantastic shortwave reception But the wire kept breaking. Finally I gave up and stuck with an indoor shorter wire.
