- Joined Jan 23, 2018
- 28,258
NO!! Crinkling will have no effect on the current path, no change in resistance.Ok, that makes sense...Wondering how I could incorporate a zig-zag if I were to try this for a temporary solution....Inside of the top cone would need to be solid, but perhaps on the outside, I could cut out a zig-zag design....Or maybe cut out strips of foil to spiral around the outside leaving gaps in between.
Would crinkling the foil also serve the same purpose of increasing resistance?
and there is an issue with aluminum, foil or otherwise, which is that it does have a tendency to corrode , especially in the presence of moisture and electrical currents.
The suggestion of using the ceramic tube style higher wattage wire-wound resistors, mentioned in post #18 is quite good, in that you could easily have a predicted wattage (power) heater that would avoid any reliability issues. And it could be small enough to fit inside the rain gage housing. And if the connections were soldered it will probably last for many years. The big challenge will be deciding how many watts of heat to provide. My suggestion is "not very much", you do not want to melt anything.. Probably some others can offer a more detailed suggestion.
