Almost electric...
Externet
Joined Nov 29, 2005
2,676
Hi all.
My microwave oven traps moisture inside its door. Takes 2+ days to dry/dissipate. Has any of you ever dismantled the door ? Can see no latches, screws, anything. Door works well, aligned, no cracks...
The exterior clear plastic window layer has 1 cm gap to the perforated inner sheet metal layer, and that has a plastic film layer adhered by the inside. Perhaps I could reseal with silicone somewhere... :rolleyes:
DMW111KPSSDD
wayneh
Joined Sep 9, 2010
18,164
Could the root problem be inadequate venting of moisture inside the oven, maybe a dead fan? I don’t know about fixing the door but maybe it’s not the real problem.
Externet
Joined Nov 29, 2005
2,676
Thanks.
Opened the oven; added air deflecting cardboard pieces to improve its working fan circulation and is a little better. Found a video to dismantle the door, cannot find the path where the steam may be getting in. Will dig deeper. Will leave the manufacturer resource for later.
