Hey guys,
I am designing an inductor for high current where i need Air gap of 6mm in order to avoid saturation.. But the thing is I am not able to find the air the ferrite material which has airgap of 6mm(one side).. So I thought of keeping a plastic of 2mm on both the legs which also make 2mm gap on the center...which makes effective air gap of 6mm (That's what i believe).
The AL value for individual gaps are given in the datasheet but that value is for middle gapped...
My concern is if i keep gap on both the legs like i mentioned, do i get the AL value mentioned in the datasheet for the airgap?
How does it make a difference by adding gap on legs?
I believe that by adding 2mm on both the side gives effective air gap of 6mm..is thst right?
Please let me know...Thank you
