Air conditioning outdoor PCB fault
deka91
Joined Aug 7, 2025
I found VFO output of IPM IKCM20L60 is high. And it's send to microcontroller TMS320F28034 via a diod and a10 K resistor. Before 10K resistor it's high 3.3V. But at MCU pin it's low. Mcu working fine other work. And MCU try to on IPM for 2 second and goes mcu output off. Can anyone help to digones this.
lichurbagan
Joined Jul 4, 2025
137
Check the type of diode being used. If it's a standard silicon diode (forward voltage around 0.7V), it could be pulling the voltage down enough that the MCU sees a low level.
