I'd send some current through it to warm it up with 1/4W if that's the rating and see what the resistance is when it's hot.With magnet?
Then compare drift to a typical metal or carbon resistor. Carbon should drift way more than metal film I think.
That doesn't always work. I bought some 1.5Ah 18500 LI-ion batteries from a seller on AliExpress. That was before I knew that many/most of the listings are fake. After getting some fake 18650's, I went back and tested the 18500's. I was fortunate that all of them delivered around 1.4Ah.Once you find a supplier who sells quality stuff, stick with that supplier for future purchases.
Second pass with the QuicKutz. I only used needle nose pliers on the ones with kinks too close to the body for the QuicKutz to deal with. Took a couple hours.I'll be doing another pass. I have an QuicKutz scrapbooking tool that I use now.
A few years back I ordered a carbon resistor kit off of ebay. They were sold as 5% they all had the gold band. I made a circuit using some of them. It didn't come close to what I was expecting. I took it apart and measured the resistors. The first on was off by 15%.But they don't "match" one says 9.66 the other 9.688. The latter (when rounded) would be 9.69 - that's not really a match.
What type of carbon? Carbon composition or carbon film? Carbon comp resistors are expected to drift with age. If they're carbon film, it sounds like you got components that were pulled from trash.A few years back I ordered a carbon resistor kit off of ebay.
I purchased a mix of 5% carbon resistors. I used three in a circuit and the circuit simply didn’t work as I was expecting. I pulled out the resistor and measured it. It was 23% .A “10K”, 1 percent, metal film (I hope) resistor from ebay:
9,688 ohms
That would be a 3.22 percent resistor.
Sigh.
Those tiny common 5V supplies... | General Electronics Chat | 16 | |
How did those phone lights work ? | General Electronics Chat | 4 |
| Similar threads |
