the first led lights up and that's all
hi,
You need to post a circuit diagram, so that we can help you.
E
That's a pcb print not a circuit diagram,, i'm guessing it's a 555 and Cd4017 chip...Will also post pics with my cell phone shortly, so you can see the finished product. Thanks for the help. I am trying to get this working so I can use it with fiber optic threads on an HO scale drive in marquee sign.
Welcome to AAC!
@Dodgydave is correct about the 555/4017 according to the spec sheet available here:
https://www.allelectronics.com/item/aec/led-chaser-kit/1.html
No schematic that I can find but a clear photo of the completed board top AND bottom will help a lot. Maybe that fresh battery will fix it.
Good luck! Thanks dodgy, I put in some pics. and completed two of them. neither works.
eric its posted now..thankshi,
E
Thanks, check the pics and you can see they are correct as far as I can tell. the 555 has a dot on the left and no notch at all. is it possible its reversed?My only thoughts are polarity. Make sure the chips are correctly installed observing the notch on the chips for correct orientation. Next make sure all of the LEDs are installed correct polarity and finally C1 is a polarized electrolytic capacitor and must be installed correctly. Everything should look like this when assembled. There really is not much to the circuit and with all parts correctly placed it should work just fine.
Ron
If you have a Dvm you can check the 555 timer for clocking pulses on pin 3, then check pin 15 on the 4017 for clocking, check the supply on both the chips,...
