Basic power supply advice please
Hello, and thanks for any advice given, first off I'd like to apolagise as I'm sure the answers I'm looking for are right infront of my nose but I have no idea what to search for that doesn't lead me to normal linear power supplies or dual voltage PSU's (i.e computers psu's with 12V/5V output).
I want to build a sound system for a chair, which will consist of 5 amplifiers. 1 amplifier requires ±36vdc 4A, and the other 4 require 16vdc 3A. I must confess I'm a little confused with the ± supply ( I imagine it as the + voltage pushing, and the - voltage pulling resulting in a net potential voltage of 72V seen by the amplifier, but I imagine alot of things so please correct me).
I've not done much with power supplies before and I just have no idea what my best options are for powering these from the same source. My essential criteria is price, the speakers and amps are cheap, It's more of a semi-novelty project.
I cannot use the normal linear power supply, since I most certainly do not want to put 240V straight into a chair (Insert electric chair joke here), so I guess my best option is to use a switching power supply in it's own external house? (Like a large laptop or xbox brick) for example http://www.aliexpress.com/item/Power-36V5A180W-concentrated-power-supply-LED-power/760468133.html .
Can i use two of these single supplies to produce a ± supply? I've seen brief references to connecting them in series with the positive from one supply to the negative of the other to create a common ground, leaving a positive and negative rail but I have no idea if this is right or safe?
I have none of the mentioned equipment yet so nothing is set in stone, I would really just like a point in the right direction. At the risk of looking stupid, I have included a quick sketch of how I currently believe I would achieve this, though I'm very unsure. I would rather look stupid and be certain when dealing with power.
I would really appreciate any advice you could throw my way, Many Thanks.
Moejoe
Moejoe
