I'm new to this forum and haven't read through all the rules yet so apologies if I do something wrong.
I'm designing a data-logger that uses a STM32F4 MCU to interface with: SRAM, Sd card, accelerometer and 2 external ADCs(SPI).
I have done the layout of a few PCBs before but this is my first time laying out + routing a 6 layer PCB with an external SRAM interface, therefore I would really appreciate if I could get some advice/feedback from those who are more qualified.
As you'll notice from the PCB file attached, I have tried to keep trace lengths between MCU and SRAM as short as possible and at similar lengths. However, I think that is not the full story and I might be missing some detail because I read in other forums that the impedance is more important. To that end I did try to use the Saturn PCB tool to try and evaluate the impedance of the tracks but then things got quite complex really fast.
I have also tried to make sure that power traces are as thick, and short, as possible to reduce EMI. Don't know if I achieved the best solution though.
Anyways, cutting a long story short... if people could give me suggestions to improve the PCB or point out mistakes that could cause the device to misbehave, I would really appreciate.
NOTE: PCB was done in eagle 7.6.0 and the size of the PCB cannot be larger that it's current size.
Thanks!
Thanks!
