Adjusting the power to a heating element.
paradox226
Joined Mar 14, 2017
I am working on a project where I am trying to adjust power going to a heating element. I am running between 12-18 watts of power. I have been looking at pots, however the ones that can handle the power are large and rather expensive. What other options are there. I am trying to keep it simple (Analog), however I can work with a digital solution. Just keep in mind I am new to electronics and learning as I go, so if you need more information just ask.
paradox226
Joined Mar 14, 2017
At what voltage does the heater run?
What is the maximum power the heater can handle?
If the heater is running on a DC voltage you could have a look at this simple PWM circuit:
https://forum.allaboutcircuits.com/threads/project-simple-pwm-circuit.9016/
Bertus
Thanks You for the link.
Yes it is running on DC Voltage. The heater will be running at 12v ~1.0-1.5A, I don't have the maximum rated power (long story). I have tested it at 14.8v@ 1.2A =17.76W and it de-soldered the leads. I will be using high temp solder and retesting it, I just wanted to be able to adjust it slowly so I don;t burn it out.
bertus
Joined Apr 5, 2008
22,994
The given circuit will run from 10 to 15 Volts when you use a standard mosfet.
With a so called logic gate mosfet, you can go down to 5 Volts.
Bertus
