adjusting the output current of a constant current LED psu
MrAl
Joined Jun 17, 2014
13,896
not, sure did not measure that yet
the smd leds are either 1W or 3W, wired in series, 15 pieces
Ok then shunting some of the current to ground is not the way to go.
I know it might be difficult, but if you can trace out the entire circuit we can figure out how to modify it. I had to do this several times in the past. Most notably with a Volvo fuel pump relay/controller board. Took a while to trace the whole thing out, but once I did that, I knew exactly what to do with it with no question about it. People have modified ATX power supplies too this way so they can use them as a sort of general-purpose adjustable power supply.
prometei
Joined Apr 13, 2008
98
[QUOTE="MrAl, post: 1850501, member: 241810"
[/QUOTE]
Yes it indeed is difficult. My pretty thin and long/sharp probes don't make it much easier. I've had to solder some wires on the bottom of the pcb, to the GDS pins of the mosfet to make this a bit easier. So far I've only traced a bit, image attached
MrAl
Joined Jun 17, 2014
13,896
[/QUOTE]
Is that a capacitor between D and S? That would be unusual.
prometei
Joined Apr 13, 2008
98
update, the ic pin connected to source is also connected to minus of the rectifier.
still have not been able to find which pin of the (supposedly) mosfet ic is VCC
prometei
Joined Apr 13, 2008
98
update: found the driver IC pin controlling the mosfet gate
- "DONE" ADS-42W900-LEP constant current LED psu outputting 900mA.
- mosfet is a sfv10n6
MrAl
Joined Jun 17, 2014
13,896
I found two smd resistors, wired in parallel giving ca. 1 ohm, connected between the source and the rectifier negative, could this be it?
That would make more sense yes, but it's unclear why the MOSFET would want to short out the positive of the rectifier to ground even with a 1 Ohm resistor in there, unless the LEDs were connected to the AC side of the rectifier or something.
It's unclear where the LEDs connect to this thing.
You can test if a connection is made or not using a multimeter on low Ohms range. First check the zeroing by shorting the two meter leads, then doing the test knowing there could be a small offset error like 0.1 to 0.5 Ohms. If the meter reads 0.2 Ohms with leads shorted, then that means zero Ohms is actually going to read 0.2 Ohms and 1 Ohms is going to reads 1.2 Ohms.
prometei
Joined Apr 13, 2008
98
re
the leds connect to the low V side of the circuit. The mosfet is on the high V side (AC mains).
In any case this is getting to complicated, I reckon I'll have to undsolder some of the bulkier through hole components on the high V side, use some short wires to solder them back to the pcb but not on it, and continue probing/tracing the circuit somewhat properly.
MrAl
Joined Jun 17, 2014
13,896
re
Yes, good idea.
Maybe this circuit will help a little...
prometei
Joined Apr 13, 2008
98
prometei
Joined Apr 13, 2008
98
The post #35 arrangement is providing voltage regulation: not current regulation.
I had that idea because my LED psu has a similar low V circuit. The only thing connecting the low and hig V sides is the blue CY4 component as shown in the attached pics
MrAl
Joined Jun 17, 2014
13,896
Yep, I know that kind of cricuit with an opto-coupler and an IC like the TL431 but in my case I think the attached schematic is much closer methodology
source: https://www.infineon.com/dgdl/Infineon-IRS2982S-DataSheet-v13_01-EN.pdf
excerpt:
I just wanted to provide some idea what you might have there even if not exact. A place to start thinking.
I still dont see any capacitor between D and S of the mosfet though, and that is almost never done because that puts a lot of stress on the mosfet when it turns on. That cap may not last very long either if the mosfet survives that is. I guess you got the part number for the mosfet from the part itself, but where did you get the idea that the cap from D to S is really a capacitor and not some other part like transient suppressor or something.
This circuit doesnt look that complicated really. It's much simpler than the fuel pump control board i talked about earlier.
I am tempted to ask you to send me the board and i'll check it over, but not sure where you live.
