Adding Library Component in LTspice.
Ahsanm445
Joined Sep 29, 2020
14
I am working on LTspice and facing a little problem. There is an error I have tried to cover but it is still not resolving, Can Anyone check it and suggest to me what should be done?
Alec_t
Joined Sep 17, 2013
15,158
You probably have the file stored in the wrong place.
If your OS is Windows10, by default LTspice expects to find the model file (.sub etc) and its symbol file (.asy) in your ....User/Documents/LTspiceXV11/lib path.
Ahsanm445
Joined Sep 29, 2020
14
Alec_t Thanks for your kind Reply,
I have tried to store the file at the right place and I double checked it many times and I also used other components in the same way and they work very well but this Component is not working properly, If You can Send me the .asy file of the SFH6136 Then I will be thankful to you.
